Going out deep
Submitted by mightymouse on Sun, 2009-04-12 09:26
hey all,
I am looking at going deep sea fishing something in the 300meters , what size sinkers ?but if anyone can suggest rigs to use and is it worth the effit.
heading out behind rotto, Also I have a lowrance sounder with broadband would that read the bottom ok or do you need a 1kw transducer??
could you please let me know. cheers
Rick
Date Joined: 22/12/06
Heavy
Don't know how much current is running out there at the moment, but you would probably need to make sure you have some 50oz leads on board. Standard Paternoster rigs will do the job but you may need to make these out of heavier leader than you normally would.
Hoping to be out tomorrow if the winds are decent.........
PGFC Member
kaneo
Date Joined: 09/01/08
40oz
40oz
mako magic
Date Joined: 03/08/05
the key to fishing out there
the key to fishing out there with baits is to be on the bottom, i would suggest atleast 48 and 50oz sinkers
PH:9248 3800 unit 3/11 Alexander drive Malaga
Tim
Date Joined: 26/09/06
Not Sure
I would think anything that will hold the bottom will be fine
. All depends on current and wind. Could be as low as 20oz but you could also need 50oz+.
Use a normal paternoster but beef it up to heavier trace material if you can.
I have a broadband and it gets bottom out there ok with a 600w transducer, just have to go slow which you have to do with the more pricey sounders anyway.
As for if its worth it only you can answer that one. Some good fish out there but also lots of crap fish which will kill you winding up from that depth all the time for them. Is really no different to fishing in closer for dhuies lots of ground to cover to find fish.
** Rockingham Offshore Fishing Club **
