Bit of Help - Concrete pool renovation
Submitted by Happy Hooker on Tue, 2016-03-08 13:23
Hi all
Just seeking some feedback around concrete pool renos ( strip plaster back/resurface duraquartz or similair /new tile band and coping) ...
Had a few quotes so know its an expensive exercise...its a 60,000 lt pool .. so any recommendations /advice from anyone who have had theirs done would be welcomed.
clogwog
Date Joined: 01/02/11
Did mine myself, used
Did mine myself, used luxapool epoxy paint, came up great. Needs to be redone every 10-12 years. Also did the edging, Bbc hardware in madding ton supplied glue that was suitable for the coping.
cost me around $1000 for the paint and $1500 for the coping, had quotes at the time for $4500 to paint and $2800 to supply and fit edging so saved a fair bit.
Sulo
Date Joined: 13/08/11
I had the replaster and tile
I had the replaster and tile surrounds done.
I used restora pool, they were good but a few short cuts caused me a few headaches, they had no idea of the issues when they did the job so not really their fault. My biggest issue was that the whole job was not sponged when they fisnished, except the top edge and the stairs. They said if I scrubbed it occasionally all of the plaster skin would come off, 6 odd years later and most of it is still there, not that it looks bad or that you can tell.
I did all of the prep work myself and got someone in to do the sandblasting.
If I had my time over I would have modified the pool from 80,000 litres to about 20,000 litres and got some of my backyard back.
Vinesh87
Have to do this myself soon,
Have to do this myself soon, out of interest what were the quotes?
My pool is totally stuffed with big holes in the bottom haha
haha
better ya pool than ya boat!
RobertMc
Date Joined: 19/01/09
if your interested i have
if your interested i have about a dozen or so left over bags of plastering pool quartz at home which im open to offers on, might save you a few dollars in materials.
Happy Hooker
Date Joined: 12/11/08
Cheers all
Am in process of doing retaining etc and paving / putting up a African thatch hut so its all turning out to be bigger than ben hur now.
Its 10m x 4 m x2.2 deep ( and with me being 2m tall I love it)... am on cnr block and as its out front size doesn't bother me, would just be lawn anyhow so pool piss easy to look after v garden and lawn.
I was looking to replaster it in the quartz plaster , get tile line redone ,coping etc .Pools around 35 years old, still in half decent nick but does need resto. They pretty much strip it back to bare concrete so its a new pool at the end of it.
But Clogwogs tidy up seems more wallet friendly at this point of time. How long ago did you do it mate and hows paint standing up ?
Vinnie I got 2 quotes.
Extreme Pool Restos - $22k and AllPool Renovations $18k
Vinnie
To give you an idea of whats involved as below:
1 Skip Bin .Subtotal
1 Remove existing skimmer box, and replace, including pressure test to
system.
1 Remove tiles, step treads, and plaster back to the concrete shell.
32 Lm Fremantle stone Limestone 270x400x40 bullnose header supplied,
and installed. Including laser levelled screed.
30 Lm 200x200 Tile band around pool, (choice of tiles from our range
including Ardex 2 part epoxy grout)
9 Lm standard step treads to edge of steps.
Adhesive, Grout, Megapoxy.
1 Collect and load pool mix.
88 m2 Supply Gemtex Quartz Sky Blue. 1 Plaster pool, and acid wash.
3 Supply and fit eye bails to finished pool.
1 Spa Electric LED blue pool light including transformer, and new cable 1 Water balance on completion (not including salt)
Vinesh87
Thanks for that, ill have to
Thanks for that, ill have to measure mine as it super deep too!
I am assuming that mine will need more work than yours haha, but to be honest 18k does not sound too bad !
Bit of no more gaps what ya think ?
Vinnie
z00m
Date Joined: 10/05/14
Jungle reclamation
Will you just end up with a little hole through the jungle to get in the front door soon Vin? ha ha
Vinesh87
Was just thinking a series of
Was just thinking a series of rope swings!
Nah had the exacavator going last week so we are clearing it up a little bit but all the big palms stay!
scottnofish
Date Joined: 28/08/07
do you live in orange grove vinne
my mate at work recognizes your pool from somewhere
Vinesh87
Wattle Grove so yeh pretty
Wattle Grove so yeh pretty much. Whoes ya mate?
petermac
Date Joined: 03/03/10
pool punp and filter
pool pump and filter don't get much use I am guessing , seriously but just bought one of those robotic pool cleaners bloody brilliant cuts pool maintance time in half leaves all those cleaners that work of the pool pump suction through the skimmer box for dead
Vinesh87
Yeh will def get one!
Happy Hooker
Vinnie at least you wont need to empty it !
At the end of the day they strip it right back so I doubt the cost is going to be any different. Am reckoning mine could be a bit bigger too .
Mines never been emptied so who knows what's it like when it is...right now there's a layer of silt in the bottom from cutting limestone blocks with quick cut for retaining walls so yours is probably cleaner ....
To save you from taking leaves etc out, I have a spit and motor, just need to find a lamb or pig !!
Vinesh87
Haha thats true! Yeh i have
Haha thats true!
Yeh i have a spit too and access to lambs. I wouldnt waste it with burning leaves only my homemade fired hardwood charcoal!
Na mines massive, super deep to i should probably measure it haha
Vinnie
