Fuel starvation issue?
Hi all,
I have a centre console with 2 fuel tanks. The front tank is located in the middle of  the boat with a fuel line length of approx 6 metres from the tank to the motor (140 Merc).
The issue is that at anything above about 5-8 knots it will run for a while and then die like it isn't getting any fuel. If i stay under that it will run OK with no cutting out.  I don't have the problem with the rear tank. Its not a breather issue either I believe.
Any suggestions on what it could be or tips to try and isolate the problem.
Date Joined: 11/05/11
I had the same problem with
Tue, 2013-02-05 15:38
I had the same problem with my boat with a 300 yammie ,the tank had a build up of junk which reduced the flow of fuel to the motor , pain in the arse as it was a new boat so the tank had to come out  and be cleaned.
davidbland50's picture
Date Joined: 24/07/11
Agreed
Tue, 2013-02-05 15:53
Overkill is right. Had the same problem with a built in tank on my old Pacemaker...once past 5 knots, it would seem as though the engine was starving of fuel. the piick up was getting blocked by scum as the tank was angled up by the boat getting up on the plane. Best bet is to blow out the tank or remove the tank and purge all its contents.
Merc hose?
Tue, 2013-02-05 16:47
Are you using mercury brand hose? Have had a few reports of late where the teflon / silicon lining comes adrift and clogs up the filter.
Make sure you don''t use common silicon to reseal the inspection plate on you tank, it reacts with petrol and forms small balls that find their way to the pick up. They block off the pick up and once the engine stops and then because of a lack of suction then drop back in the tank , rolling round waiting to get sucked up again. Happened to me once and took ages to find the problem. Sikaflex is the stuff to use.
Date Joined: 02/01/11
Do those fuel additives that
Tue, 2013-02-05 16:50
Do those fuel additives that clean the injectors, etc you put in cars also work for outboard motors ???
Date Joined: 28/05/12
Don't believe its Mercury
Sat, 2013-02-09 13:45
Don't believe its Mercury hose and Im beginning to think the dirty tank could be the issue which will be a bugger to get out. Thanks for all suggestions.
Good fishing.
snappermiles's picture
Date Joined: 05/11/10
check your filters
Sat, 2013-02-09 14:35
water seperator and also your Breathers are not clogged up, also check the small fuel filter on your motor!
