Best autopilot for 7m ali boat
Submitted by Stoinka on Mon, 2017-01-16 16:46
Just wanted some opinions on which autopilot seems to work best in a small boat.
Apparently Garmin is the go due to its highly responsive compass.
So anyone with a Simrad or any make! I would love to here your views before I commit.
Cheers Stoinka
dodgy
My next one will be raymarine
My next one will be raymarine ev100 I reckon
resurgence
Date Joined: 23/04/14
Best?
Furuno 711C with SC30 sat compass.
Tim
Date Joined: 26/09/06
Yep
Bryce Day
Date Joined: 01/06/15
$$$$ setup that 1
$$$$ setup that 1
resurgence
Agreed
But arguably the best setup around.
Subaquatic
Date Joined: 23/04/11
I've got the Lowrance with a
I've got the Lowrance with a HDS. Does a pretty good job, and was reasonably cheap.
cutter
Date Joined: 30/12/10
Simrad
Just installed Simrad Autopilot in 8 meter ally boat with Nss evo simrad gear. Tried it on the weekend and its awesome.
resurgence
Current system?
I suspect your best option will be driven more by what current chartplotter system you currently have, unless you want to run the AP independently.
Stoinka
Date Joined: 02/09/06
Thanks alot
for everyones response. Will go the Simrad path, cheers.
t bone
Date Joined: 20/04/14
SIMRAD
I just installed a NAVICO unit that is paired up with my simrad also. took a few beers to dig deep thru the settings and stuff for the vitual rudder feedback, but once got that set up she runs great. Really easy to set and operate from the headunit also. Do a bit of research into what GPS your going to use thou. the "point-1" compass is only good for inshore & near shore they reckon. Then they have the RC42 option thats better for offshore. Then you can then step upto the bigger ones like the HS60 that gives you even more options again.
Glen.vit
Date Joined: 11/01/11
i have raymarine es128 with
i have raymarine es128 with Raymarine Ev200, Pimp Daddy
dodgy
Not on a sterndrive by any
Not on a sterndrive by any chance glen?
Glen.vit
Hi Dodgy the Raymarine
Hi Dodgy the Raymarine autopilot is hydraulic (type1), has its own pump. So quiet. its on a 7m glass boat. Highly reccommend
Glen.vit
