two rocks/ Lancelin and Jurien bay offshore fishing help and general guide
Submitted by surfymuzz on Tue, 2019-03-26 11:03
Hey guys, fairly new to fishing and would love to get pointed in the right direction for general area to head offshore from two rocks/Lancelin and jurien bay.
I have a 580SF haines so i can get out as far as i need to go.
If anyone could help that would be great!
happy to return the favour on some spots SOR if needed :)
im using a furuno 585 with a p66 transudcer as well if thats helps
makai
Date Joined: 28/10/08
Google & Fishwrecked
There have been a lot of posts on the places you want to fish. The site search function is not working, but if you Goggle the location and put Fishwrecked in your search string (eg. Jurien Bay Fishwrecked), you will locate the old posts
D_d_001
Date Joined: 09/03/13
site search function works
site search function works fine........just click in it and type whatever. nothing shows in the box but press enter and wha.la
Work the contour lines, the
Work the contour lines, the pros are in a bit closer now also so good time to pick up their ground.
Travis p
Date Joined: 28/07/16
Few wrecks out that way
Google is your friend
Brock O
Have fished two rocks a few
Have fished two rocks a few times...last few trips to 35-40 meters, as mentioned above use the contour lines....always a few Pro pots out there to do a search on to get started.
Have found most of my good Dhues / Baldies on the flat hard ground...not much in the way of structure out there I've found.
Shit loads more productive than Freo....just additional travel and fuel costs.
Meeuwissen
Date Joined: 29/03/13
head out nw
from two rocks put some lure out and mark ground as you troll. Then find a contour lines as everyone has mentioned and out tow sea anchors there are some many baldies out there
Down the Line
Catch the Experience
