motor cutting out while idling and cutting out when put inot gear
Hi all, Im having an issue with my motor cutting out when idling, went out with my son this morning and the motor cut out whilst in nuetral, I went to start the motor and it started and then a few seconds later it cut out. this happened several times, i first removed the fuel line from the motor to ensure fuel was getting through which it was and then i pumped the line a few times and it did eventually start and we raced back to hillarys, could it be something simple as dirty fuel/ i do keep the tank full at all times and do have a water seperator on the boat which does show some sediment on the bottom is there an additive that can be added or should i empty the tank completely. My other thought was that there could be a blockage in the line somewhere, does the fuel have a filter that could bve blocked with sediment
thanks for any advice forthcoming
MALANA605
Date Joined: 25/11/17
it is an old honda 130 not
it is an old honda 130 not quite sure how old but at least 10 years old
MALANA605
CRESTCUTTER251
Date Joined: 28/11/18
Maybe just cold or need to
Maybe just cold or need to adjust the idle ? Mine cuts out if its cold too
if you cant tie knots, tie lots
Scotte
Date Joined: 07/12/06
First check would be the
First check would be the iac.
Undo the two bolts, disconnect the connector and then clean the little gauze screen with a quick spray of carby cleaner. Not too much.
Regarding the sediment in the water seperator.You should be replacing all the fuel filters as part of your maintenance and certainly if you have any crap enter the tank.
There are 2 fuel filters on this engine plus the water seperator, there is one on the high pressure filter on the vst and the low pressure one.they both are very easy to change.
Start with the iac and see if that fixes it.
Mooseknuckle
Date Joined: 14/05/13
Old Honda issue with throttle body
I recall the old Hondas have an issue with the throttle body jamming/sticking and causing stalling.
Little Johnny had his son Luke's fixed - maybe he can shed some light.
Scotte
At idle the throttle blade
At idle the throttle blade is closed and all air going into the engine is down the bypass thru the iac..
Check the iac on the throttle body..
