Fuel sitting in tank
Hey Guys, my boat has been laid up for a few weeks now (due to work commitments) and I'm just wondering what you blokes do with the fuel sitting in your tank?
I try and keep mine full at all times but after coming back from a fishing trip its only 1/4 full (a 530l fuel tank is a lot of extra weight when towing).
Would you fill it back up or can you put an additive in it to capture any moisture due to condensation?
Obvious answer just keep using it!!!
West is Best
 A small amount of metho to
Fri, 2014-07-25 10:25
 A small amount of metho to get the moisture out. You'll need to google the amount per fuel to put in. You can buy an anti ageing  agent for fuel as well.
Ashen's picture
Date Joined: 22/03/13
 Use "Stabil" which is
Fri, 2014-07-25 13:59
 Use "Stabil" which is available at BCF or Supercheap. It helps keep the fuel "fresh".
t bone's picture
Date Joined: 20/04/14
interesting point
Fri, 2014-07-25 14:33
Just throwing it out there, im a sparky, not a mechanic.
But i work away also, with a minium hitch of 4 weeks. Sometimes my boat will sit up to 3 or more months. All i do is throw the trailer up on set of axel stands and drain the tanks. The missus loves having a 44 drum at home to fill her car up with. Then next time i do head out, just fill up. I havent had issues yet (only 200ltrs over 2 tanks) but  only had boat 3 yrs too..  i never really gave the moisture thing a thought
 be careful not to use the
Fri, 2014-07-25 15:19
 be careful not to use the ethanol blend fuels, (only sold from United Rangeway in Gero that I know of) as they are the real danger both for marine use and sitting long term.
t bone's picture
Pro's and con's
Sat, 2014-07-26 08:05
From what i have heard, it can be great, and it can ruin a motor depending on what its running. Ive got an old 98 GU patrol that i run it on, but has had more $$ put into the motor than what i paid for the car & tuned to run the stuff. When i come back to work, pretty much drain the lot, then dump 10 ltrs of premium in it and run it thru ready to sit for the 5 weeks. Have heard its really good at eating rubber fuel lines, injector O-rings and blocking up carby jets if left to long thou??
Your bang on the money with United in rangeway mate, but i also think one of the "shell" servo's do it also, cant remember which one thou.
 not sure if you know,
Sat, 2014-07-26 09:24
 not sure if you know, ethanol (like biodiesel) will absorb water where the mineral fuel won't.
So when ethanol blends get water in the tank bottom, at a certain point the ethanol falls out of suspension from the mineral fuel.
When that happens your outboard runs on 95% ethanol and a percentage of water which causes big problems.
http://www.alloutdoor.com/2013/06/25/fishermen-beware-ethanol-fuel-deadly-outboard-motors/
adamibinfishin's picture
Date Joined: 16/03/14
fuel
Fri, 2014-07-25 16:51
Hi bud,
fuel sitting around for a few weeks is no big deal. metho seems to work or you can also top up tank with premium fuel or use stabil or fuel additive products.To be honest premium will sort you out if sitting around for a while and if unsure just run your engine at home first to make sure engine seems ok,hope that helps buddy.
regards Adam
 Thank Adam, stabil was stuff
Fri, 2014-07-25 16:54
 Thank Adam, stabil was stuff I was thinking of
with Stabil, Im pretty
Fri, 2014-07-25 17:01
with Stabil, Im pretty certain you need to add it when the fuel is new, it will preserve but not restore stale fuel?
Ethanol is the #1 danger though
 You are right Rob. I've got
Fri, 2014-07-25 17:07
 You are right Rob. I've got some in the shed for my whipper snipper funnily enough. As far as boat fuel goes, my boat sits for a few months over winter and have never had a problem, just fill the tank with fresh fuel at the start of the season.
chris raff's picture
Date Joined: 09/02/10
So at what point would people
Fri, 2014-07-25 18:02
So at what point would people in the know , consider fuel to be too old to use and does it being 2 or 4 stroke affect the longevity ?
Saltlife .. a Robalo R235 ... they look like a nice tub are they yank made 25ft yeah   , how do you rate them in our waters ?
Niko's picture
Date Joined: 26/11/13
auto mechanic
Fri, 2014-07-25 18:30
 Fuel life will differ to a degree depending on how its stored, weather etc (will go bad faster in high temps or acumulate water faster in high humidy) but generally around 3 months ud be pushing it and even that would depend in the engine it runs. Really modern highly strung, high performance engines its alot more important to keep the fuel fresh. That being said I dont drive my car very often and got to about 2 months on the same tank, 2013 toyota 86 high compression direct injected 4 cyl tuned for 98 and it still went fine (although I wasnt happy about it and drove straight to the servo). As for 2 and 4 stroke I cant say.
saltlife's picture
Date Joined: 14/02/14
Cheers for your input guys, I
Sat, 2014-07-26 07:05
Cheers for your input guys, I think I will fill her up this weekend and try get out over the coming weeks.
Chris - yeah that's the model (R235). I rate them highly, had it for 2 years and not a single issue yet. Good solid hull with all the fruit.
West is Best
