fuel litres
any mathmatic smarties here
my fuel tank is 1800L x 530w x140h
how many litres
135?
Date Joined: 09/11/06
i work it out to be
Fri, 2016-07-08 17:12
I work it out to be 133.56 litres
(1800 x 530 x 140 ) divided by 1000
walloped's picture
Date Joined: 08/04/12
 Check where you fuel intake
Fri, 2016-07-08 17:17
 Check where your fuel intake is and remember to subtract the area below that as it will be fuel that you cant use.
Date Joined: 10/06/09
cool thanks
Fri, 2016-07-08 17:22
cool thanks
Paul H's picture
 L = Litres, its 1800L Don't
Fri, 2016-07-08 20:27
but don't blame me when you run out
Ericl's picture
Date Joined: 02/05/11
133.56
Fri, 2016-07-08 23:49
Agree with Paul N, 133.56 (unless these are outside dimensions in which case it will probably be about 130)
Doc's picture
Date Joined: 29/05/16
the tank in our motorhome is
Sat, 2016-07-09 05:14
the fuel tank in our motorhome is 1800L X 900W X 750H which equals a little over 1200 litres, but loses a small amount with baffles etc inside.
Broome lad's picture
Date Joined: 16/11/15
Regal tanks
Sat, 2016-07-09 08:22
 Web site has a free calculator for tanks of all shapes just type in measurements and hit the calculate button Give you litres gallons
epic restos and marine's picture
Date Joined: 22/06/15
 if the tank is perfectly
Sat, 2016-07-09 11:07
 if the tank is perfectly rectangular its 133.56ltrs
Walfootrot's picture
Date Joined: 23/07/12
plus whats in the filler hose
Sat, 2016-07-09 11:28
plus whats in the filler hose lol.......
