Fuel Economy
Submitted by BQ544 on Tue, 2008-09-23 19:47
Been talking to different outboard dealers about the improvement in fuel economy switching from 2 stroke carburetted to a new 4 stroke or high tech 2 stroke. They all claim 50% or better fuel economy but know one will guarantee it. My question is has anyone taken a 5 year old 115 hp carburetted 2 stroke off a 20 foot fibreglass boat and replaced it with a 115hp 4 stroke or new high tech 2 stroke that can give me exact improvements in fuel economy?
thanks
Darryl
Tim
Date Joined: 26/09/06
Fuel
Havent got a direct comparison for you Darryl but I changed from an 18ft ally with a 115 jonno 2 banger which was only 2 years old to a 20ft glass boat with a 140 4 stroke and my fuel usage has dropped by at least a third over the same trip.
Felt it was a great improvement for a bigger boat and motor.
Hopefully someone has some direct comparison figures for you.
** Rockingham Offshore Fishing Club **
harro
Date Joined: 07/02/08
150 yamaha 4 stroke
same, not really same comparison but i have a quite a few boats, 9 in fact, and all types of motors, one thing i will tell u is,
right now i have the biggest boat i have ever had 650 walkaround, 7metre hull, shes a heavy 6mm aly rig, and i have a 150hp 4 stroke yammy on her.
she moves and is a dream on fuel.. i have driven all day sounding ground out from nats reefs way right out past the c.lumps in one day,n reefs are around 25nm out, then another 3o +to the c lumps from there.. even down towarrds cowaramup, i have never used more than 80litres of fuel in one day.
this thing is that quiet , sometimes i,ve thought it was on, and tried restarting after a drift..the prop on this boat makes a big diff also, on my last 620 quinny, i had a stainless prop, could never get the same torque,nor the revs needed to power in when needed.. the aly prop seems to handle alot better on the heavier rig..
i,ve had a 115 also equally good,
i,m already thinking of getting an upgrade of benj,s boat..
8.5 walkaround with twin 150hp 4 strokes..
prob next year sometime.. normal running this uses anything between 7.5 and 11.5 litres of fuel an hr depending on conditions etc..
:::: Bass Hunter ::::
jersey
Date Joined: 12/06/08
Chalk & Cheese
I have a Yamy 200,direct fuel injection on a grady white that is solid gpr,at 4,000 to 4300 doing around 30K I got approx 50lts an hour with 5 men on board,I think the thing you must weigh up is the added cost of a four as the 2 stroke,debending on the use you get it may take a long time to recover the extra cost from fuel,but ,personally ,I would love a 4 for my next but 3 or 4 grand buys a bit of fuel,just think it through,two are reliable as are the 4 but I think the Yamy hpdi is more technical to do the the pressure injection,desienged for racing so just do the maths
jesrey
Justin Poole
Date Joined: 24/08/08
Southwind UB 670
I have a 90 yammy 2001 model, 90litre fuel tank,
25 nautical & I am at the half a tank mark,
Is this normal for such a beast?
It seems i will have to carry jerry cans to get out after the grey band cod and other species to feed my family after the Ban,
What do these boats run like with a 100 or 80 four stroke on the back? will a 90 E Tec do just as good? any other suggestions?
By Hook or Spear, its all good..
Justin Poole
e tec or 4 stroke
e tec or 4 stroke?
VAGABOND
Date Joined: 04/06/07
Recently put a new 200hp
Recently put a new 200hp Suzuki on the boat, saving around 40% on fuel comparing to the old 175hp Two stroke. Done around 25 hours so far and very happy with the change. Using between .7 to .8 of a litre per 1km, so to do 100km we use between 70lt and 80lt. The Seafarer 6.2m is a heavy boat so you could even get better on a lighter Glas boat or a Ally? @ 4000rpm we are doing around 30knots, @ WOT 5800rpm we are doing around 45 knots.
damo6230
Date Joined: 07/06/08
fuel
recently swaped from 2 to a 4 stroke 60hp yammie. saving good 40% but the killer for me is cleaner environment.....and oh so quiet...
wrassmaster, not sure about your figures!!! 25 Nmiles is 47km = 45litre (half tank)which is roughly 1 lt per km. mine 60 2 stroke would do that on average.... I thought those southwinds were designed to take a smalll engine with good economy....no expert on the boats though just what I've read.
my 4 stroke 60hp yammie should get me on average 4.02km per litre at 3500rpm. i have a 100 litre tank so long range. one thing with my dig dials is the last fuel bar flashes but easy 30 litres left, must be where float is located.....
eTec or 4stroke......well i went 4stroke because it was an old yammie and the conversion saved me heaps of $$ cuase same gauges etc otherwise i would go Etec and next boat will be Etec.....they wanted to charge an extra $1000 for the Etec but the best quote i got was on a 4stroke yammie period. but yammies are good.
big john
Digital
Those digital gauges have a reserve built in. If you look in the manual you can change the amount remaining in the tank when you get to the last bar.
My 200l tank is set at 170L on my fuel gauge, when it get's there I know I've still got 30 litres up my sleeve.
Best thing about the Yamaha fuel management system is its accuracy. If mine says I've used 70 litres, when I fill up I will be within 1 litre of that amount.
John
I head a little FURTHER NORTH each year,
Leave the cities behind, out of sight of mind,
kaneo
Date Joined: 09/01/08
got the same 90 yam 40km to
got the same 90 yam 40km to 25ltr of fuel at 3500
Mick
Date Joined: 28/08/06
G'day BQ To be honest I
G'day BQ
To be honest I would have thought that a 115hp on a 20' glass hull would be underpowered. What sort of hull is it? What sort of speed does it get up with beer and gear on board? Personally I would be looking at a larger engine. It will be working a lot less under the same conditions and load and using a hell of a lot less fuel.
Cheers mick
If the lord did not mean for us to eat fish and game, he wouldn't have made them outta meat
The speed of light is faster than the speed of sound. That's why so many people appear bright...until they speak.
VAGABOND
Agree, under powering a boat
Agree, under powering a boat will cost you in the long run, more fuel, more stress on the engine and bad resale. Some of the engine and boat set ups you see in yards are a joke, way underpowered and the only reason can be to keep the package price down?
Bodie
Date Joined: 05/11/07
2 boats 1st in a 6.1
2 boats
1st in a 6.1 Razorline with a 135 honda 4stk
Uses around just over 1 litre per mile at the moment
2nd boat is a 25 blackwatch (Mates boat) has 2 x 200hp optimax engines 2 stk
Uses 2 litres per mile exactly.
In comparison, i would say optimax's are better on fuel, but a power to weight ratio does play a part.
BQ544
Date Joined: 22/10/06
very interesting fiqures...
very interesting fiqures... I think if the economic downturn recovers a bit I will look at 4 stroke and maybe go up to a 140.
Maverick
Date Joined: 06/06/06
2 to 4
I took a 70 HP 2 stroke merc off my 5.2 m and put a 60hp 4 stroke Yammy on it and get 3 times the fuel econmy than the old 2 stroke. I get around 30 to 35 NM from a 25 l tank.
I love my Yammy .
________________________________________________________________________
OFW Agent 88 , the Scarecrow.
OFW member 088
Maverick
Ohh yeah
And I get better speed from the 60 4stroke than the 70 2stroke ever did, and trolling is a dream .
OFW member 088
Economy
I've got a 5.0 metre ali,all 4mm plate,with a 60 etec on it.Normally use 35-40litres on a trip to the islands[30nm]and running around,usually 80nm for a trip sitting on 2500-2700 giving 22-24knots.
