Electric reel battery
Submitted by Curndog on Thu, 2024-04-25 11:11
Hi guys,
recently bought an electric reel to take fishing up north. Haven't bought a battery yet but just wondering what everyone uses and what's the most economical to do the job? Probably only use it few times a year. Do I just buy a car battery and then trickle charge after each day of fishing? Any advice is appreciated
Go to battery world and tell
Go to battery world and tell them what you want one for. We got ours from there and havnt had a problem . About the size of a motorcycle battery
selthy
Date Joined: 27/05/11
Check out the Maph electric
Check out the Maph electric reel battery. WA based company. I went out a few weeks ago with a lad that had one of these and looked really convenient.
Quobbarockhopper
Date Joined: 28/05/10
Ive just ordered one of the
Ive just ordered one of the 10000MAH models. the details say they apparently last a full day deep dropping but I have my doubts. Does anyone have any expereince that could confirm this? I know there is a lot of variables (depths, amount of fish caught etc as the reel would obviously draw the most power when fighting them) but I would really like to know if its realistic to expect them to last a full day fishing, and catching, in the 150-200m range?
thanks heaps
Quobbarockhopper
thanks heaps
greyheads1
Date Joined: 27/08/11
there was a very good post
there was a very good post recently on Laith Rickmans reel servicing facebook page, the Maph battery seemed to stack up technologically against hose utilising the itech jump start kits and similar. However from what Ive read - you're looking at 4 drops ish.....will see if i can find the posts and copy the text in.
I run a 120 ah deep cycle through a Kings battery box and that takes two Seaborg Megatwin 1200's (as the box allows for the twin connections).
Mark_M
Date Joined: 10/04/15
Mapheox
https://www.facebook.com/story.php/?story_fbid=737440208518309&id=100067570097042&paipv=0&eav=Afb_jggTEY096n2g-67NnW-KroRiSTZzz83lyh6Vxii7J1d6hwv04cqVoUi3mKpTB9g&_rdr
Maverick
Date Joined: 06/06/06
Deep Cycle
Car battery is good to start a car but that is about it, you need a deep cycle for constant power, you could hook it up to a solar charger to keep it topped up between trips with it.
OFW member 088
Alan James
Date Joined: 30/06/09
I use one of these and have had no issues.
https://www.batteriesdirect.com.au/shop/product/22430/dc26-12.html
Alpha
Date Joined: 13/02/17
Why not
Why not just use the boat battery? If you got alligator clips just hook on.
Maverick
And then
And then if it drains the battery you can't start the motor ?? Most car and boat batteries are made to give a large amperage surge to start a motor then let the motor run everything , you can kill a battery in a car with just a minute or 2 of cranking but a deep cycle can run a campsite for days with fridges, lights, radios etc and just recharge them with no harm done. Most dual battery systems in a camper has a main hi amp battery just for the car and run a deep cycle for the fridge etc while out and about, after starting your car the Alt recharges the bit it took to start the car and then switch over and then trickle charge the deep cycle to keep it topped up.
I have helped out a few people that had run their battery low and were a hundred plus KM from any service and no cell phone towers out there. One guy was stuck at False enterance in Shark bay for 3 days and were running low on food and water, we were camped only 25 km away but it could of been 250 as neither of us knew about the other and the UHF radios didn't work over that distance, I have been going up there since 1981 and there was NOTHING up there back then, even the track was hard to see going into Steep Point. (I spent Xmas in 84 up there and we had the point all to ourselves for 4 days of a 2 week trip.)Even towed a few boat into Ocean reef marina when they had electrical gremlins hit their boat.
not having a go at you buddy just a long answer from someone that has been at both ends of that situation ( my dad started taking me and my brother camping every second weekend from age 5 and I only stopped when a work accident stopped me about 7-8 years ago, I turn 61 this year).
My Daughter was conceived in the sand dunes at Steep point back in '88 , wink wink.
OFW member 088
Just leave the motor running
Just leave the motor running while in use.
tot
Date Joined: 31/01/10
I don't
DD that much (2 - 3 trips a year) and find I usually have motor running when drifting so I just clip to the house battery.
moose hunter
Date Joined: 14/06/13
My two bobs worth,if you use
My two bobs worth,
if you use boat battery and run it flat, how much would you pay for a deep cycle then?
I'm with maverick, deep cycle and avoid any potential issues, chuck a set of jumper leads in and you have 2nd battery for boat if you already don't have one
moose hunter
My two bobs worth,
jighead
Date Joined: 03/02/12
You can say that again.
Maverick
I am
I am allways right.
Real world experience here (and there , ohh and over there too.)
OFW member 088
The Saint
Date Joined: 30/01/13
I haven't deep dropped now
I haven't deep dropped now for quite some time, but back when I did, we always ran 2 reels off the start battery.
Could fish all day and not have a problem, but that was with dual battery set up so there was always backup for just in case...
scubafish
Date Joined: 15/08/12
Helpfull tip
Third Batt:Emg use 100amh 12v wired up with iso switch to charge when running eng & isolate when not in use,would prob be in deep water not anchoring and motor idling anyway/drifting/spot lock.
ebay.Anderson plugs.
