Battery Recommendations
One of my Odyssey batteries died on me, much to my surprise, so looking for a replacement.  Need at least 800CCA and would prefer maintenance free, so I don 't have to top up the battery water.  What do you folks recommend?
Are you batteries the same?
Mon, 2009-02-16 13:37
Are you batteries the same? Or is one more for running devices and the other for cranking?
Edit: mmm agm
alfred's picture
Date Joined: 12/01/07
They are the same and AGM.
Mon, 2009-02-16 18:19
They are the same and AGM.  Haven't set them up for accessories and cranking yet, guess it's time as I have the bits.
18 Outrage, Johnson 140hp 4stroke and 190 Outrage, 150 Mercury Verado
Andy's picture
Date Joined: 08/10/05
Stick with the AGM battery
Mon, 2009-02-16 18:28
Stick with the AGM battery that you have. they are telling us to rig all the new verados will AGM batterys. The odyssey batts are the go.
Hmm I thought you had AGMs,
Mon, 2009-02-16 19:16
Hmm I thought you had AGMs, sorry to hear it died =(
I didn't realise they were that senstive to overdrawing!
bump
Tue, 2009-02-17 10:32
On this topic, I have a 30 yamaha, running a vhf and 27 meg, and will be putting in a new sounder from my old b/w job to a navman 4600 and 600 transduecer, is it advisable to upgrade the battery with the increased drain required to run the new unit?
Manual Start
Tue, 2009-02-17 11:09
No sparky myself but I reckon the existing size small car battery should be fine Adam.
Your only running those electronics from the battery as its a manual start donk. Every time you run somewhere its getting topped up.
John
I head a little FURTHER NORTH each year,
Leave the cities behind, out of sight of mind,
roberta's picture
Date Joined: 08/07/08
We've got heavy duty marine $170-$200
Tue, 2009-02-17 11:17
 sealed and it runs the sounder/radio/gps, never had  any trouble with batteries expensive but worth the money, every two yrs Bob buys a new one and the old one goes on the boat winch.
 Don't know the name of battery but cost $180
SPEWIE LEWIE
Cockburn Power Boat Member
Ginger Tablets Rock
Andy's picture
Yer adam as long as your
Wed, 2009-02-18 15:40
Yer adam as long as your engine has a charging unit, (rectifier regulator)you will be ok.
