Yammie 2 banger problems
 G'day all having a few dramas with my 115 2 banger seems to be only firing on only 3 cylinders won't idle it's got 4 brand new plugs in it and only 3 seem to show any signs of use so what I am trying to work out is could it be a dodgy lead thats breaking down or could it be the cdi unit if anyone knows of any quick tests or tricks i could try and also I can't find any info on the particular model the numbers are 115 CETO  6E5 L 410823 R .
Cheers carry
Tradewind's picture
Date Joined: 18/09/12
First thing i'd be checking
Sat, 2013-12-14 12:57
First thing i'd be checking is visually looking for a spark in each cylinder
Date Joined: 22/02/10
 I had an issue with my 3cyl
Sat, 2013-12-14 14:08
 I had an issue with my 3cyl 60hp yammie 2 stroke.  Barely running on 2 cylinders and certainly didn't wNt to Idle !
After a bit of tinkering I found The bottom carby was rooted , had some water come through fuel and it sat in the bowl corroding the whole lot out !!
if you can eliminate the spark issue maybe check that !!
Carry's picture
Date Joined: 22/04/09
Yep just checked
 Yep just checked spark on each plug all got spark and boat seems to idle ok at home just when I put it in the water it doesn't want to play the game.
Carry's picture
Just had
Sat, 2013-12-14 14:12
 Just had carbies professionally cleaned drained and cleanedfuel tank twice all new fuel lines and fittings new racor water trap filter and new fuel bowl thinking electrics now
tim-o's picture
Harder to fire a cyl
Sat, 2013-12-14 17:22
Harder to fire a cyl under.load, prob an ign issue. Pull the plugs after a run on the water to determine the cyl at fault (fouled, black plug), clean plugs and swap faulty cyl lead with another. If the fault is still with the same cyl (fouled plug again) then the coil (or trigger to coil) is at fault if it has individual coils (or a comp issue, but u said its fine at home so wont be), if the fouled plug is now the new cyl the lead got swapped to, then the lead is faulty. Basic four stroke missfire diagnosis, but should be the same with 2 bangas
Carry's picture
Cheers timo
Sat, 2013-12-14 18:25
 Cheers timo will give it a bash i notice yammie got a special on at the moment on 115 4 bangas missus is shuddering hahaha.the other thing is timo 3 of the cylinders are pretty dirty with one being relitavely clean dunno if that helps.
tim-o's picture
Individual carb per cyl? You
Sat, 2013-12-14 18:57
Individual carb per cyl? You got a cyl with no fuel then maybe. Has the problem occured since u had carby work done?
Date Joined: 08/01/09
Sounds like a hole in the water jacket
Sat, 2013-12-14 19:24
that is letting water into the top of the piston!! Had a similar thing happen to an older 2 stroke 40hp yammie. If your spark plug is nice and clean and shiny thats what it will be..
FEEEISH ONNN!!!
Carry's picture
carbs
Sat, 2013-12-14 19:26
Bit hard to say timo i had dramas with the motor bogging down in low revs 2000 rpm to 3000rpm but then she would kick in and run at 3500rpm to full noise no problem and since the carbies have been done it just doesnt seem to want to idle on the water but does at home also hard to start on the water you need to choke it up and as the revs die down kick it into gear and give it a bit to get moving im not real mechanically minded when it comes to carbies bit to finnicky to me .
tim-o's picture
Ahh, hang on, I know what
Sat, 2013-12-14 19:31
Ahh, hang on, I know what will fix it, you have already told me, a four stroke.......dont want to be having them dramas out on the water
Carry's picture
Hahaha
Sat, 2013-12-14 21:20
 Hahaha my savings account will be hurting
Ask Santa for a new one.
Tue, 2013-12-17 12:09
Carry - Just buy a new 150 verado - so we can race.
Surley your Missus will let ya buy one - Hahaha
If everything seems under control, you're just not going fast enough
Mine did - new 225 being fitted as I type
Tue, 2013-12-17 12:18
Best Chrissy pres ever !
Carry's picture
I think not
Tue, 2013-12-17 14:10
 I reckon the new quad i got out the back probably stuffed my chances but im working on it
Date Joined: 12/05/12
Similar occurrence
Tue, 2013-12-17 19:00
 My four stroke was hard to start and rough running until opened up...from Marine Doctor inspection found one carby had a blockage so only running on three carbs. Had all carbs cleaned new o rings, gaskets now runs a dream again. Was advised not to operate in such state as could burn a hole in a piston.
Can be frustrating working through this sort of thing!
