Why is one engine using more than 50% more fuel?
Any advice appreciated on this.
Boat is 32Ft Penguin (see picture) twin newly reconditioned crate 350 chev vortec motors. Both motors have new HEI distributors ( motors just completed 20 hours) with 650 holleys, shaft drive and new props. Very heavy boat at 8t and then some but this is the bit that worries me. Recently headed out about 25 km plus drifting plus trying a few spots for about 4 hours in calm seas most of the work done at about 3100 - 3200rpm where the boat sits nicely on plane. Always conscious of keeping both engines the same rpm.
Filled it up after the trip as follows:
Starboard motor tank took 81.25 litres
Port motor tank took 149.05 litres !!!
As far as I can tell there are no leaks, both motors sitting at temp and staying there with equal oil pressures. Motors both fire up at first kick every time and sound the same when turning over.
I do catch the smell of fuel every now and then when the boat s going but not much from up the top.
Where do I start:
Float levels, timing, it's a huge difference. I would be ok with the 80 litre top up for each motor.
Appreciate you help or suggestions with this.
ROUGH RED
One day I hope to replace the boat picture I am using with one of a decent fish...One day...
Props
Have a look at your props, could be they are different pitches or the stern gland on one side is tight causing extra load on that engine.
Do they have a return line back to the fuel tanks, could be that they both return to one tank not both, otherwise its in the tuning side of things.
Escape
Date Joined: 14/12/11
Thanks Carnarvonite, I hadn't
Thanks Carnarvonite, I hadn't thought of the stern gland, I will check that the shaft can freely rotate. There are no return lines as such so can count that one out. Both props were made to order at the same time so should be ok...(I hope).
If it is the tuning side of things can a simple thing like a float level adjustment make the difference?
ROUGH RED
Stern gland
You should get a drop of water every 30 seconds or there abouts if its one of the older glands, just enough to lubricate the seal. If you give it a squirt or three of grease when you return to the pen it should stop the drip whole the boat isn't being used.
Float levels can increase fuel usage but not by as much as you describe and Id be getting someone to check out this whiff of petrol, its a perfect recipe for the boat to up with a huge bang'.
Escape
I have a feeling you are
I have a feeling you are right, pretty sure the area under the gland is staying dry.
I hear you about the petrol smell - from what I can tell it's out from the exhaust like its either running with the choke partially on or something like that.
Thanks again
ROUGH RED
alfred
Date Joined: 12/01/07
Swap the props over if they
Swap the props over if they are not counter rotating and see if changes the consumption. If it doesn't at least you know the props are ok.
Escape
B&##!er, I was hoping to not
B&##!er, I was hoping to not lift it out of the water for a while yet, oh well. Thanks for the suggestion Alfred, appreciated
ROUGH RED
DTrain
Date Joined: 10/02/12
You could start with pulling
You could start with pulling a spark plug off the engine. If it is brown and sooty then you know that you have a rich fuel condition which is likely related to your carberettor tuning.
If it is clean and white then the problem would be something else such as fuel leak or propellor setup.
seaswirl
Date Joined: 29/08/10
check to see if there is an
check to see if there is an equalizing line that connects the two tanks .....fuel could be moving between the tanks....are you 100% sure that both tanks were full when you started....fuel flo meters have come down in price in the last few years, they are a very helpful tool for getting the best economy...good luck
CCC
Date Joined: 29/03/10
Could be the taco is faulty.
Could be the taco is faulty. Try running the thristy motor with a bit less RMP or borrow a portable taco gun and check the RPM while cruising. Maybe the thirsty motor is running harder and the less thristy is not working hard at all.
CCC
Georgejungle
Date Joined: 25/03/09
Props would be able to be
Props would be able to be change with scuba escape. Are both motors in the same engine cowl ,Blocked air flow? will drastically increase fuel usage partially blocked air filters?.I am still thinking your tanks are linked or not balanced that is a huge difference.
Escape
Thanks everybody for the
Thanks everybody for the ideas.
I wont be able to get to the boat until the weekend but will do the checks everybody mentioned.
Georgejungle, motors sit wide apart in separate housings with reasonable vents. I will need to look at the tanks more closely, to see if they are joined in some way.
I wonder what would happen if I swapped the fuel lines over?
ccc, I do have access to the equipment you are talking about so can also give that a go. Maybe I do need to get fuel flow meters for reassurance.
ROUGH RED
CCC
Sorry mate live in Port
Sorry mate live in Port Hedland so wont be able to help but I sure if you search the net you will find a cheap hand held taco or see if you can borrow on from a motor mechanic.
See below
http://www.megabuy.com.au/digital-tachometer-p208401.html
Escape
Problem solved
Just back from the Rottnest Convoy with over 4.5 hours on the water Saturday and with good conditions we were sitting on mostly 16 -17 knots. She is a thirsty beast but the fill at Rottnest this time was within 10 litres on roughly 125 litres a side.
Only thing I did was to back of the packing glands as per one of the earlier suggestions. I am pretty sure I had a blocked breather and an air lock the last time around.
Much happier now.
Thanks everybody.
ROUGH RED
No problimo
No problems, all part of the service.
handy having the old farts
handy having the old farts around that know their boats and bits. showing your vintage there John
Looks
Definitely haven't got good looks going for me any more so have to rely on whats stored in the brainbox over the years.
