Water Pump
Hey all that have a Land cruiser 60 series, mines 62 water pump has just blown was sitting at peron looking at the coast thinking its very fishie any one have any idea on what they are worth ? can you fit a 2nd hand one in, is it worth it ? TT
Date Joined: 09/08/08
180 bucks from coventrys.
Fri, 2010-01-29 18:20
180 bucks from coventrys.  Dont waste your time with second hand.
sarcasm0's picture
Date Joined: 25/06/09
Agree
Fri, 2010-01-29 18:25
Also, go through and check absolutely every radiator/cooling hose as often after replacing one hose or the pump, the others like to go.
Date Joined: 25/07/05
cheers MickWas hoping it
Wed, 2025-09-24 07:46
cheers Mick Was hoping it wasn't going to cost the earth thanks again TT
Ok I got the water pump OK
Sat, 2010-01-30 13:11
Ok I got the water pump OK 190 it cost me
almost got it out, but one problem, one of the blots has snapped, but its still sticking out of the block with some thread on it, a little rusty thou
any tips on how to get it out ?
TT ( karl )
sarcasm0's picture
sheared off bolt
Sat, 2010-01-30 13:28
Ok, you can try liberal applications of crc/wd40 and if there is enough thread sticking out possibly put two nuts onto the thread, put the first one on tight and then lock it with the second one.  Then carefully using a spanner on the first nut(the one closest to the block) try to get it out.  I have also heard of a "cold" spray which literally chills the metal down causing the threaded section to contract, hopefully enough to break it free from the block.
If this doesnt work or there isnt enough thread, you can look into either hacksawing across the end of the sheard bolt, and using a screwdriver attempt to get it out.  Also you can grind/file down both sides of the sheared section to give you something to hold with an adjustable spanner or visegrips.
If that fails then you drill out the sheared section with a  small diameter drill (maybe 1/2 the size of the threaded section) and then there is a tool called a bolt remover(maybe some other brand name) which you turn into the smaller hole and attempt to turn it out.
Here is a website with some other ideas : http://quayvipersmcc.websitetoolbox.com/post?id=1577470
Good Luck!
Thank you sarcasm0 I'll
Sat, 2010-01-30 13:38
Thank you sarcasm0
I'll give it a read and have a go before removing the radiator. what a pain in th a$$ hey..
TT ( karl )
sarcasm0's picture
Always is a pain in the arse for a sheared bolt
Sat, 2010-01-30 13:43
Looks like you have plenty of remainder sticking out.  Some other things I read suggested that if it sheared the main bolt because it was rusted in, the screw extractors are useless as they will likely shear and then make it bloody difficult to drill out.  They basically said drill it out and retap the section.
Now that is a pain in the arse! Hope it doesnt come to this.
Hey I got it hey out, I put
Sat, 2010-01-30 14:02
Hey I got it hey out, I put a pair of monkey grips on it and it turned and came out, must of had the bloke up stairs on my side..
Thank you so much guys for all the tips
this forum is one of the best for help on any thing
TT ( karl )
sarcasm0's picture
Well theres luck for you!
Sat, 2010-01-30 14:03
Not a problem.
Bryan
here's what it looks
here's what it looks like TT
