Water in fuel
I stress that I am not accusing anyone BUT since my boat is permanently parked at CPBA for convenience I only fill the tank from the Blue Shed and only ever use premium from that location.  Just had my boat serviced by Chivers and they reported excessive amount of water in the filter and commented that they have seen at least 5 other boats who all launch at Woodies with similar issues over the last month or so.......I intend mentioning it to the owner when down there on Thursday but just a heads up as the facts seem to speak for themselves. Have now fitted a glass water separator bowl so I can monitor the issue
hezzy's picture
Date Joined: 27/11/09
sunshine , id also go into
Tue, 2018-12-18 14:02
sunshine , id also go into repco or similar store and ask for the product they sell , specifically to remove /deal with water in fuel , cant recall its exact name but 1066 rings abell
they will know anyway ...it works a treat
you drain your fuel filter,/water seprator , clean it and add this to the main tank as well
OFW 11
Dhunitough's picture
Date Joined: 31/01/18
 Hi sunshine grab yourself a
Tue, 2018-12-18 14:33
 Hi sunshine grab yourself a bottle of fuel treatment/stabiliser, best by a long shot is f-10 by ICT.
Date Joined: 16/08/09
That’s interesting. I had the
Tue, 2018-12-18 15:01
That’s interesting. I had the same problem with my boat that I used to fill with premium at the same spot. Water in the fuel, killed my engine. When they drained the tank about 15L of fresh water came out. I ended up having to repower my boat. I don’t fill up there anymore. I would make sure you drain your tank completely. I was still getting water in fuel alarms after the fuel had been drained becasue anything left below the pick up remained - and that was all water. I ended up removing the sender unit and draining the tank through there to get everything out. New fuel, different supplier and no problems since. I also keep my boat at cpba our of interest.
 not good at all . especially
Tue, 2018-12-18 15:53
 not good at all . especially when your paying for the good stuff. def would think twice about using the same supplier. thankfully i have a glass bowl filter in mine , found water in there once so now keep a good eye on it and drain a bit every time we go out to make sure
Date Joined: 29/04/18
 Definitely  not  the first
Tue, 2018-12-18 19:10
 Definitely  not  the first  time  that  i have  heard of water in the  fuel coming from this place , the ladies there are great and make a great burger  but i sure don't  get fuel from there
 Happy dayz
I thought a cup of
Tue, 2018-12-18 20:24
Metho was the go. In a big tank . Evaps all the water .See through separaters 100 percent way to go.
Has anybody taken
Tue, 2018-12-18 21:27
Has anybody taken the problem up to the fuel supplier and made him/her aware that there appears to be a water contamination problem with the fuel they are suppling.
They may not have a clue that there is a problem with fuel that they dispense.
Which is why I am dropping in there on Thursday
Tue, 2018-12-18 21:20
Manning sea rescue in the morning but yes I will certainly be informing them straight after
 I'm sure that they are aware
Wed, 2018-12-19 03:40
 I'm sure that they are aware , the most recent  time i have heard of this was maybe 2 years ago seems like an ongoing  issue  there,  as i said before  its not a risk im willing  to  take  but i always  pop in and buy something  else  there great little  shop
 Happy dayz
johno's picture
Date Joined: 20/07/08
Thanks for sharing, makes me
Wed, 2018-12-19 06:58
Thanks for sharing, makes me think twice now about buying my fuel there, I am heading back to Perth now.. and haven't been buying few there for a number of years but will think twice, I like the shop and the convivence knowing you can get fuel.
PGFC
Date Joined: 31/12/11
Humid conditions can also create water issues
Wed, 2018-12-19 11:05
In your case Sunshine unfortunately a tank drain is essential to be sure. Large amounts obviously can't be removed with additives.
I live in the Kimberley where humidity is a huge factor when boats aren't being used for extended periods.
Like Little Johnny said, i put about 250ml of Metho in every tank, and have done so for 15 years. Never a problem. I was told buy a fuel truck driver originally, but i have since asked a fuel chemist who agreed, and said keep doing it.
My motor has just clocked up 1000hrs and i have been using Metho since day 1.
An explanation why Metho works
Wed, 2018-12-19 12:06
Try this link, explains well how metho helps dissolve water.
https://autoexpert.com.au/posts/qa/how-do-i-fix-water-in-the-fuel-tank
Despite now identifying 5 effected boats
Thu, 2018-12-20 17:00
Dropped in at lunch time and quietly spoke to the owner who reckoned they checked after other reports two weeks ago and found no water......wife used to work at a servo and doubts they can actually check unless they decant into a large clear container but to their credit they have promised to check again and will ring me with the results
Date Joined: 16/05/09
Unless they check the bottom
Fri, 2018-12-21 06:28
Unless they check the bottom 200mm of the tank it won't show anything. We have a new servo up here that has tanks that let water in during our wet season. Most of those in the know steer clear of it for fuel. They have been spoken to but always deny its their fuel.
Date Joined: 30/12/09
Is that in Broome in the
Fri, 2018-12-21 10:22
Is that in Broome in the lia?
yep you know the one as you
Fri, 2018-12-21 11:39
yep you know the one as you come into town
Darren253's picture
Date Joined: 23/07/16
I don't use that location for
Thu, 2018-12-20 17:19
I don't use that location for anything other than bait, ice, tackle and a cracking bacon roll... But i too had water in fuel alarm come up on the boat yesterday. My tank is only 18months old and almost always stored 90% full so i don't believe in can be condensation.
I will be adding a glass bowl over the weekend.
After the ongoing problems I
Fri, 2018-12-21 06:55
After the ongoing problems I had I got one of these, works a treat.
https://www.chsmith.com.au/Products/Fuel-Filter-Bowl-Alloy-and-Alarm-Inc-Harness.html
Darren253's picture
On special at Whitworths
Fri, 2018-12-21 09:50
Checking for water
Fri, 2018-12-21 07:05
 The supplier should check for water in their tanks weekly, it is done by putting a special paste on the bottom section of their tank dipstick. Any moisture in the bottom of the tank changes the colour of the paste when the tank is dipped, then comes the hard part for them is getting rid of the water and if they can be bothered is another question.
Date Joined: 25/11/15
 I allways thougth in this
Fri, 2018-12-21 10:28
 I allways thougth in this country you innocent untill proven guilty but not on this forum , condensation maybe and where is the filler cap is it exsposed the the rain as the seal could be the problem . Ask the question as they might have the tanks checked regularly ?
 thats on the boat i mean
Fri, 2018-12-21 12:20
Not only is the fuel seal perfect
Fri, 2018-12-21 12:41
But the boat has a full waterproof cover.  As a courtesy I spoke to the manager off to the side as other customers were present.  This I s the sole location I fill the tank so the source of the water bluntly speaks for itself.  Further to avoid condensation issues the tank is filled to the top on every trip.  Sorry but unless you can come up with a logical explanation guilty as charged!  They still make the BEST bacon and egg toasties in the West and their home made sausage rolls are equally delicious but I will be driving further for fuel from now on
 Certainly makes sence to
Fri, 2018-12-21 13:48
 Certainly makes sence to me.
Not worth risking getting stuck out there and having to rely on sea rescue fo something that could be avoided even if its only suspission.
Doc's picture
Date Joined: 29/05/16
Water in fuel is a huge risk
Fri, 2018-12-21 18:06
Water in fuel is a huge risk for us, even filling up at places you wouldn’t expect it, but more so in the tropics. I drain my inline filter system every time I pull up, have it set up on the discharge of the fuel tank before it goes through the fuel counter and on to the motor and genny
