water in boat
Submitted by mikeurnot on Wed, 2020-06-24 12:28
Hi Have a Barron Sportsman and have a pod attached to the back . My question is during lay over in winter the boat fills up with water .
There where bung holes under boat but someone has filled them in . Should I put in new bungs and does this help over winter months ?
Noticed the the pod on the back has one bung hole under it . I close it when I am at sea is this right ?
Read on some sites that the pod should fill with water . Confused as to why ?
Any help ?
If the holes have been
If the holes have been filled I'm guessing the one in the pod has to run through to the hull. If water is left in the boat it could mean trouble .
bradz
Date Joined: 29/10/07
Pod fill with water. No.
No. I would not encourage you to have the pod fill with water. You may be referring to balast tanks... but not a pod.
JW77
Date Joined: 16/06/15
Definately don't fill the
Definately don't fill the pod with water. In respect to the hull, it should be dry and aired out after use. Water left in the hull will end with problems such as rot. If the boat is stored out in the weather get yourself a tarp or cover to protect it dueing the winter months.
Live to fish
scubafish
Date Joined: 15/08/12
Stability
Stability at rest, fills with water at rest too add stability and has a self drainage hole and empties when you take off.
Pod chamber must be waterproof .Dah !
P.S and yes should be a seperate bung to the main hull.
mikeurnot
Date Joined: 05/05/11
Well finally got the
Well finally got the water out found a bung inside the boat . Got it out and the water went out fast looked under boat to see where it was coming from .
There is a v in the pod near transom when you look under it you dont see it . Well getting a new bung plug to put in and just have to get on my back to put it in before I go out .
Thanks all for your help .
scubafish
PIC
Pictures tell a thousand words.Interesting to see one.
Some people put a reverse bug in the boat so they can remove it(unscrew it ) when traveling along to get rid of any excess water then put it back in once removed.
Another Tip:
Laminate a checklist of things to do at ramp before boat goes in the water eg.
remove tie downs x2
Put bungs in x 2
Check safety chain
Flares,life jackets.
etc,etc,
And reverse before leaving ramp to drive home.
Pilots do it all the time ,WHY ,because it will save your life and or someone else's.
meglodon
Good idea scubafish
As you get older (more mature) your memory is not as sharp as you would like to think it is and having a visual reminder of things to check before you put to see is something that could save you a lot of embarrassment when you get going to launch.
scubafish
Some things in life are free .
My advice and life experiences will always be free,"take it or not".
