under water photograpy
hey guys and gals
i want to get into a bit of under water photograhy on scuba and was wonder wat everyone noes and some pointers for me. in the way of camera and general tips i would be very much appreciated
cheers flagpole
if you are only going
Wed, 2009-10-28 22:35
if you are only going shallow the olympus u/water camera does well , only waterproof to 10 mtrs, also when using u/water try and have the sun behind you so there is no glare as well as having the flash turned on unless the water is sooty..... ps.. the olympus can be picked up for under $600 and they can do video with sound u/water as well
Chuditch's picture
Date Joined: 15/07/09
Depends on what kind of
Wed, 2009-10-28 22:24
Depends on what kind of camera you have obviously. SLR underwater housings can cost as much as the camera.
flagpole's picture
i dont have a camera yet wat
Wed, 2009-10-28 22:38
i dont have a camera yet wat is the best one and i'm looking at going to full 18m and looking at doing a cource to 30m, so i think the olympus is not rated for the depths i might be going to
kaney68's picture
Date Joined: 29/07/08
you will probably need to look at
Wed, 2009-10-28 23:00
You will probably need to look at a reasonable quality housing something along the lines of Ikelite, Sea&Sea, Nimar, Aquatech.
Prices vary considerably across brands and also dependant on what model camera is being housed and lens option..
For example a 350D or 450D would be a damn sight cheaper than a housing for a 1D.
Therefore you will need to consider what DSLR and lens options you will intend to use.
Then you will have to get the appropriate lens ports and consider strobe housings or dedicated u/w srobes.
Alternatively...
Maybe have a look on ebay (both .com and .com.au) and do a search on underwater camera housings and also on the brands listed above..
You can sometimes get some bloody good buys... I was almost tempted a few months ago to get an Ikelite housing, lens port and camera.
Just figured it would be more practical to get a housing to suit my current DSLR's rather than downgrading.
tonyb's picture
Date Joined: 10/11/08
Just ordered the below from
Wed, 2009-10-28 23:18
Just ordered the below from one of our suppliers.  Not sure on the quality but was recommended by PDA, they wanted $1100 inc GST so I was pretty happy about these prices.
MJU8000 in stock, 1 in Black and 2 in Silver. $379+ In stockThe under water PT-045 housing we will need to order in for you (Note: non cancelable once ordered). $259+ ETA from order if Olympus have stock 4 working days.Olympus only do a 2GB card $29+ In stock
flagpole's picture
where did you order that
Thu, 2009-10-29 15:39
where did you order that from mate
tonyb's picture
J Mills in Balcatta but they
Thu, 2009-10-29 19:46
J Mills in Balcatta but they are a distributor not reseller.
alfred's picture
Date Joined: 12/01/07
If you want to go deep, you
Thu, 2009-10-29 07:06
If you want to go deep, you will need an external flash.
Get a camera where you can access manual setings.
Find a housing where you can later add a wide angle lens.
Reefmonkey's picture
Date Joined: 22/09/08
agreed
Thu, 2009-10-29 21:55
i second that, definately get a camera with manual settings
 Dave J.
tailor marc's picture
Date Joined: 27/09/06
Take a look
Thu, 2009-10-29 15:59
Take a look here......
http://www.wadivers.com.au/forums/viewforum.php?f=5&sid=6145c08bd9145f26d27b3c256dcb39f6
Colt_Striker's picture
Date Joined: 26/07/09
I have a Cannon A710
Fri, 2009-10-30 13:23
I Brought a normal digital camera & underwater housing, the Cannon A710 has image stabaliser as well. Took some Great pics & video with sound on the Coolidge in Vanuatu down to 60m, even though housing only rated to 40m, just had to make sure it was on before going past about 35m otherwise pressure on the buttons would stuff you around. I also find that if you dive with a wreck light it is a lot better for your pictures than a flash as much less back scatter.
