Trim and tilt issue
Submitted by Silver Fox on Mon, 2020-01-06 13:52
My Verado 175 has an issue with the trim and tilt.
Motor works fine and there's plenty of fluid in the reservoir , yet it's staying in the up position when the switch is activated . Any ideas what this could be and a good way to troubleshoot ? .
Cheers in advance .
scubafish
Date Joined: 15/08/12
Try
Undo manual release ?
Marineboy
Date Joined: 14/03/14
Might be silly
Might sound silly but has the safety latch that you flick over when doing maintenance accidentally been engaged ?
Shark1
Date Joined: 21/05/12
there should be 2 relays 1
1 for up 1 down
if 1 relay is blown - wont work in one way - both blown well obvioulsy no movement
cheapish fix
Shark1
if it is relay u can buy em
if it is relay u can buy em of repco etc
just look at pin number - open closed etc
google it
Silver Fox
Date Joined: 19/06/14
Thanks guys
Boats is in the water so I don't want to open the release screw and not be able to get the leg back up . The safety latch hasn't been deployed and there's no movement either way . I'll have a look at the relays in the morning . F@2#3;g boats !
dmck
Date Joined: 07/03/19
tilt relays...
Fixed another tilt relay problem only a few weeks ago. Lucky I had spares in my tool box (automotive ones)
Dont get hung up on the genuine article..... a relay is a relay is a relay.
I just bought 12 on ebay for future similar disaters.
Just make sure you check how many pins your relay has and get the same (usually 4 or 5 pins)... also go for a minimum of 40 amps.
You should be ale to hear the relay 'click' when the switch is activated... but that doesnt mean the internal contacts (switch) is functioning correctly.
Oh... find out if you have a single motor to drive the RAM or 2..... it makes a difference to the wiring and how you test further.
Worst problem you may encounter is the 'genuine relay' may not have compatible connectors with a REPCO/other one. A competent auto electrician will be able to work it out.
FIrst one I ever did saved a mate some $1000 over buying the genuine SUZUKI ...
scubafish
Relay
https://www.boats.net/catalog/mercury/outboard-by-hp/175hp/1b517159-up-usa-cat-90-898164008/electrical-box-components
24&25
https://www.boats.net/catalog/mercury/outboard-by-hp/175hp/1b517159-up-usa-cat-90-898164008/power-trim-components
Silver Fox
News Flash
Forgot to add that the pump motor is operating. Trim up , motor works, trim down , motor works. No fluid is being pumped me thinks . Like I said F @#$%+g boats ! ( just as well there's two motors on it ... :)
scubafish
Your Welcome
Good Luck With That !
little johnny
My bushes gone in mine
Few wacks with lead works for 2 trips. Then stops goes up but not down yammy . Sometimes other way
