kempy's picture
Date Joined: 28/05/09
i can help u wid the third 1
Sat, 2010-11-20 21:17
i can help u wid the third 1 martins trailer parts are the best if you tell them the specs u want they should b able to sort it out
from memory , for the A
Sat, 2010-11-20 23:40
from memory , for the A frame  it would be minimum 5mm and for all other you could get away with 3mm, as far as roadworthiness goes, all lights must be working with all wiring tucked away and no rust on the major framework but better with no rust at all
Date Joined: 04/11/09
thanks for
Wed, 2010-11-24 20:43
the info guys
fisho-ron's picture
Date Joined: 26/09/09
mate, i used to build
Wed, 2010-11-24 20:48
mate,
i used to build trailers for 15 years, pm me for more info if you want and i will pass my mobile number on to you.
i have been out of it for 10 years now, but not alot has changed.
most things are straight forward.
cheers ron
I have sorted a few trailers
Wed, 2010-11-24 20:52
I have sorted a few trailers for friends over time. Rust is the biggest problem. You should check the main angle frame underneath. For an $80 trailer you either got a real bargain or a binable item.
