Trailer Bearings / Axle Help
Hi all , decided to get motivated and check ( buddy ) bearings on the tinny trailer . Jacked it up and found 1 side had a small amount of play the other none . Proceeded to take them apart to check for wear and to possibly replace or repack grease . Upon doing so , I discovered the side with a bit of play had the normal two shoulders on the spindle yet the opposite spindle just one .. Time for a beer break as I had to ponder .. any excuse , anyway currently thinking it might be a factory fault as both rear bearings sit flush at the first shoulder it just takes a little encouragement to get the rear plastic seal on the single shoulder side .
I've taken a pic of the worst bearing and the rear seals looked fine but I'll replace all those anyway .. off to Martins Trailers tomorrow for bits .
Questions - Thoughts on axle spindle
- How much if any play is acceptable ? as the bearings and hub races didn't look too bad .
- There was grease spatter inside both rims , I presume from over filling yet both rear seals are intact in good condition ?
Doing my apprenticeship on the tinny then I'll do the bigger trailer , so any advice would be much appreciated .. Please find some pics for your perusal .
Thanks in advance , regards Chris
scubafish
Date Joined: 15/08/12
AXLE
PM sent.
http://img.gg/BQ91Sys
Jeff Hugo
Date Joined: 14/09/09
Speedy sleeve
Chris,
By the look of the images one side has a good clean area for the seal to seal on, the other has a good amount of pitted corrosion, you may need to install a speedy sleeve on that side so the seal has a nice clean area to seal on.
replace all bearings, it is evident that water has been in there looking at the image of the inner race.
Jeff
chris raff
Date Joined: 09/02/10
Thanks for the assisitance
Thanks for the assisitance guys on here and others via pm .. will hopefully refit it all today and back crabbing asap ..cheers
