Tap Tap Prop shaft
 Hi all
I have a 115 Etec, recently had a gearbox rebuild, probably only done 10 hours since. Prop shaft was bent.
So been out a few times no hassle, only tonight after just a small outing, come home to flush the motor with muffs and turn her on to her a tap tap tap, down around the bottom of the gearbox..turn it of and when I rotate prop, you can hear the gears meshing, alsoo there is play in the prop, I can wiggle it side to side.
Been one big fuck up after another as motor is not that old, guys that serviced it for first few services told me some water in oil but didnt pick up on bent shaft.
Took it to Chivers last time who did the rebuild..
Thoughts ??
Swompa's picture
 Mine (75 Etec) clicks as I
Fri, 2015-11-13 20:01
 Mine (75 Etec) clicks as I spin the prop. Always has. Just had its first service and still does.
Date Joined: 27/10/11
Thanks Swompa
Fri, 2015-11-13 21:13
 Thanks Swompa
I wasnt to concerned about that in a way but wanted to know if its normal so thanks. The knocking or tap tap noise down there whn its running has me worried somthing needs adjusting or wasnt done correctly on rebuild
Swompa's picture
 PM me your mobile number, I
Sat, 2015-11-14 05:03
 PM me your mobile number, I can send you video of the noise mine makes, which is apparently "normal"
Get it checked out
Fri, 2015-11-13 23:08
Being out on the ocean and having something go wrong with the drive end of your motor would not make for a good experience.
Your comment "I can wiggle it side to side" is a cause for alarm bells to ring It is possible both of these things may be connected. Don't forget that old saying a stich in time saves 9, or something like that.
Will get it checked
Sat, 2015-11-14 08:25
 As I first stated, I was pissed of with issues,and previuos services.. I have to state that it wasnt with Chivers who did a great job. Im hopefull its just some adjustments, and Chivers has kindly and promptly offered to give it all a once over for no charge. Which is both good news and great service. So I will keep you up to date as to any issues or what was needed so anybody in the future may use it as a guide
Auslobster's picture
Date Joined: 03/05/08
Mine's a 90hp etec...
Sat, 2015-11-14 09:30
 ....eight years old now and has never made a noise like that...sounds a bit of a worry.
On another note, and probably unrelated, do yourself a favour and only run it on premium unleaded if you're not already doing so!
Date Joined: 08/10/13
gear selector.
Sat, 2015-11-14 10:22
 Sounds like the gear selector needs adjusting a touch. Just not going all the way out of gear.  A friend of mine bought a new box from the US it was way cheaper than aussie rebuild. That was when the dollar was good though about 2 years ago.
Good offer from Chivers
Sat, 2015-11-14 15:16
That's a real good offer from chivers, a real good company IMO.
When you get the results can you please post them so that we can all learn from it.
Simple fix
Sun, 2015-11-15 09:17
 Took the boat to Chivers yesterday, and straight away the boys were on to it. Simply an adjustment of the gear selector cable.
Like most boat owners, I don't know the inner workings of my outboard and I don't fiddle with it.. I leave it to the experts. If I had of messed around I have no doubt I would of made a simple fix worse.
And also upon hearing the noise in the lower unit I initially basically panicked and thought, "great more money".
So lesson learnt, leave it the pros, and Don't jump to conclusions.
Thanks again Chivers, you have my future business...
