Suzuki dt75 not charging
Submitted by GraemeE on Sun, 2019-03-24 18:32
Gday guys,have a dt75 which isnt charging the battery.Had a play with it this afternoon and is showing 15vac at magneto but nothing further down the line.Thinking maybe rectifier is stuffed or broken wire. Is there anyway of checking rectifier or does anyone kow where i can get hold of a wiring diagram. Ithink its a 93 or 94 model by the plate
Cheers Graeme
scubafish
Date Joined: 15/08/12
dangar
https://www.youtube.com/watch?v=vO1iYyqsUEg
http://img.gg/BQ91Sys
Bluedog
Date Joined: 28/07/11
I had the same issue with my
I had the same issue with my Yammy. Tested the rectifier with a multimeter and it appeared no good. Replaced the rectifier and now all good
GraemeE
Date Joined: 13/11/17
Thanks guys.. i did a
Thanks guys.. i did a conversion on my old 25 so thought this one might be a bit more complicated... get 13.5vdc out of rectifier but soon as i plug wire back in it drops to 12.8vdc.. had a blown fuse which threw me as white wire became a red wire to fuse where 2nd fuse was white. Will get a chance to run it up in a couple of weeks
