Suzuki df140 corrosion issue.
This may have already been done to death but if it hasn’t and you own a Suzuki df140 or it’s white cousin the Johnson 140 like I do between the years 2002 and 2007 it might be worth reading this. I will cut a long story short in the wisdom of the gurus at Suzuki they decided to place a mild steel plug in an alloy exhaust jacket component which is exposed to salt water and hot exhaust gases. Dis similar metals in that environment spells disaster a hole in motor and hot exhaust gasses burning out a wire loom that runs next to the fail zone. I just recently removed the plug by tig welding a 10 mm bolt to the plug once removed the corrosion was obvious. There was only one thread left on the female part of the thread. I have heard of people welding up the hole, I cleaned it up and built up the corroded area with plasti bond which is temp rated and bonds very well with Alli , get your hands on a m18 x1.5 tap and tap hole. Purchase a gold plug which are made for this issue. For more info on this issue google df140 engine holder corrosion. If ya got one of these motors looking at buying a pre loved boat motor package or know someone who has one worth looking at. I will try post some pics but not sure how. Hope this helps cheers Todd
Ron Ashcroft
Date Joined: 22/11/07
Thanks for sharing this mate
Thanks for sharing this mate i was aware of this but have been slack with it. I will have to get on to it. Where did you source the gold plug? When i researched it before you coild only get them from America cheers.
wangler
Date Joined: 26/04/08
I have a new gold plug
for sale $40
Dougie
todd davies
Date Joined: 14/03/16
Don’t leave it.
Www. goldplug.com and yes there from the USA.
Not only 140, 115 and 90
Not only 140, 115 and 90 also.
See my thread from a few years back
http://fishwrecked.com/forum/suzuki-df90-115-140-exhaust-issue
todd davies
Wasn’t 100%sure
Yer thought as much but wasn’t 100% sure on the 90 and 115. It can be a show stopper if it lets go the more people aware the better.
If you get the engine code
If you get the engine code flash up you can get home with cowling off.
SeperateKnob
Date Joined: 28/11/16
That gold plug looks schmick
Cheers for this info. I have
Cheers for this info. I have a 2006 140hp jhonno. Will be looking at mine when I get home from work
reelentless
Date Joined: 13/02/07
Had the same issue with an
Had the same issue with an old boat, took me a while to figure out what was going on. Ended up making a plug from aluminium bar and welding in there as my thread was knackered.
Ron Ashcroft
Thanks for the offer Wangler
Thanks for the offer Wangler but i reckon i'll just get it welded up cheers.
