steering cable
Submitted by lurcha on Wed, 2010-01-20 20:39
Hey guys was just wondering if anyone could shed some light on when to replace ya steering cable on ya boat rather then waiting for it to break? My boats 5 years old and being my first I dont really have any experience with the matter so any advice would be appreciated.
Matt T
Date Joined: 19/11/07
1986
We only just replaced the steering cable in the bayliner and it was built in 1986. I rekon you'll be alright for a while. Just use inox though - no marine grease.
wide open
Date Joined: 24/12/09
um steering cable, why you worrying about that
they last forever as long as you dont let it rust and seize, your boats 5 years old, it would be sometime before i even think about replace it
Maintenance
Every year or so pull the centre cable right out and inspect it for wear,clean off any hard build ups,re grease and put it back on.
Lack of use and maintenance are the biggest killers of cables,most of them just seize up in the slide on the outboard.
Matt T
Canarvonite
Canarvonite is spot on. The slide bar on the out board is what you have to look after. That's what seized on mine.
wide open
everyweek
just hop on your boat evry week and just turn the steering back and forth, its also got a grease nipple regrease every know and then
Matt T
Spot on with the weekly turn
But i've found the grease just clogs it up. Been told from a few sources that best just to use inox not marine grease despite the nipple. I cleaned out the grease on mine and replaced it with inox and it is easier than ever.
lurcha
Date Joined: 29/12/09
cheeers guys will take on
cheeers guys will take on board! only asked caus my mates snapped on him once but his boat was over 10 years old.
stilly
Date Joined: 10/08/09
the best thing to lubricate
the best thing to lubricate with is actually a little bit of gearlube of anykind you can actually buy a pump similiar to a grease gun which screws straight onto a gear lube squeeze bottle
wide open
well
it has got a greae nipple for a reason, you shoulnt need to worry bout the cable as carnarvonite said its the slide that siezes
