Starter Motor Winch
Submitted by CC106 on Tue, 2017-02-21 15:21
I am guessing this topic has been raised 1000 times, But I don't care I am bringing it up again.
I am building a starter motor winch using a Gear Reduction Toyota Camry starter motor, trouble is I don't know the rpm.
What size pulleys are you blokes using if you have something similar? Would like a fairly quick retrieve rate.
Shark1
Date Joined: 21/05/12
bigger pulley more speed less
bigger pulley more speed less grunt
i use a 42 inch pulley comes up with the speed of white light
30 or 22 would have been better
8m 2.8t boat
Likc
Date Joined: 09/08/09
Toyota manual says "Most
Toyota manual says "Most engines require a cranking speed of about 200 rpm". So roughly about that.
There was a good thread on this on Ausfish
www.ausfish.com.au/vforum/showthread.php/127202-starter-motor-for-winch/page3
This link takes you to page 3, not much real info before that. They talk about different kinds of starters, and ratios to use.
CC106
Date Joined: 07/01/14
Cheers everyone
Cheers everyone
Anyfishwilldo (not verified)
Date Joined: 01/01/70
I'll measure mine today,
I'll measure mine today, once it's all done you won't go back to a hand winch again!
CC106
Yeah I'm hoping not to ever
Yeah I'm hoping not to ever have to winch again! Will await your measurements
Weel on the winch is 300mm
Weel on the winch is 300mm attached to the 1:5 ratio
wheel on the starter motor is 30mm
pulls the boat up pretty quick (7-9 seconds) and doesn't struggle on the steeper ramps, I have a quintrex 490 that would weigh in about a 1T when going back on the trailer... I use a 120 amp trip out switch as a isolator that works fine, anything smaller Can't handle the load...
i also pulled the manual winch apart and turned the shaft around for the 3:1 ratio, I can now use the manual handle for the 3:1 with the flywheel still in place as the manual handle is on the opisate side of the flywheel...
crano
Date Joined: 04/11/09
300mm
I have got a 300mm diameter pulley on a VP commodore starter motor. It has been on 3 boats and it now pulls up a 6m glass boat with ease and quickly.
I have got 25mm cables suppling it which is a big factor in how they perform.
meglodon
Ford starter motor and fly wheel
I didn't bother going to the expense of pulleys and vee belts. Just used the starter motor and the fly wheel of an old ford falcon, welded the fly wheel to the shaft on the hand winch, then set up the starter motor so that the gear on the starter engages the fly wheel when energised. This pulls my 6m quinine up from what ever ramp in 16 seconds flat. I use the same size electric cable that is used for batteries and a heavy amp trip switch (forgot size) and have had this setup for 6 years with no trouble. Total cost $25-00 for cable and a slab of beer for starter motor and fly wheel.
CC106
Thanks a heap for the info
rodfishsa
Date Joined: 29/03/13
G'dayI had one of these on
G'day
I had one of these on our last boat, a mate had built a few before and I just assisted here and there. Bought a new V8 ford starter off ebay and a mazda (I think) flywheel from a wreckers (sorry - automotive dismantler). My main input though is the switch. Mate told me to go to an auto parts store and get a hella motor bike brake light switch (from memory), this was attached to a pull string and to the trailer so you could pull on it straight away when you connect the cable. I left it long enough to walk back and keep it going as I went. Keeps you away a bit for a while.
A set of ear plugs are handy as well, they are VERY NOISY but very good
Rod
