Squeeky car brake help
Not too long ago i changed the brake pads all round on my patrol, but not long after i changed them they started getting a little squeeky, and its hugely annoying and embarrasing, does any body have any idea's on trying to make the noise stop at all? besides not using brakes at allTongue out
Colin Hay's picture
Date Joined: 23/10/07
Have you checked your brake fluid
Wed, 2009-06-03 13:20
There may also be dust on the pads.
alfred's picture
Date Joined: 12/01/07
The squeek is usually caused
Wed, 2009-06-03 13:24
The squeek is usually caused by wear on the disc, usually the center is worn but the edge is not.  Machining the disc when changing pads will take care of the problem.
For a quick fix, say if selling the car, pull the pads and put shoe polish on them. this is a short term fix.
Date Joined: 01/01/70
Copperslip mate....
Wed, 2009-06-03 13:30
It is a copper compound grease that soaks into the pad and lubricates the disk - be careful not to apply too much - take a 1/2 teaspoonful on the end of your finger and smear a line from the inner hub to the outer edge across both sides of your disc. Taking the wheel off makes it easier, but if you have mags you will be able to do the outer disc fairly easily.
Warning - Do 1 wheel at a time and then ride it till it is hot, to soak into the pad - your braking on that wheel will be poor for the first few pumps, so don't hoon around while your heating it up - also don't burn your fingers off when doing the second wheel - the disc will be very hot. Just be sensible when doing this - maybe leave it a day between front and rear application, starting with the noisiest wheel.....
The problem is that the pads in are too hard - will last long, but less efficient....
Get the grease from a autoshop or tool sales place..
upg's picture
Date Joined: 25/06/07
common problem  put some
Wed, 2009-06-03 13:40
common problem
 put some stop squeak where the piston contacts the pads
can buy it at supercheap,autoone, repco..etc
i wouldnt be putting any sort of lube near the braking surfaces
mako magic's picture
Date Joined: 03/08/05
thanks guys for your help,
Wed, 2009-06-03 13:44
thanks guys for your help, and the idea of the products to purchase, i knew there was some stuff available.
Colin, no issues with fluid, i always make sure thats full
Colin Hay's picture
Some gold info there Not like my crap suggestions
Wed, 2009-06-03 14:07
Now I know how to stop my sqeaking brakes too. Thanks guys.
Big Fella fishn's picture
Date Joined: 04/05/09
Squeeling brakes
Wed, 2009-06-03 14:39
I agree with Davebarry most likely cause is you got hard pads. I disagree with putting anything on them to make them quiet, as it can be very dangerous. Best solution is to remove your brake pads again and get a hacksaw and cut some criss cross grooves in them (Making diamond patterns) about 3mm deep. This will get rid of your noise. I am qualified mechanic and have encountered this numerous times.
7739ian's picture
Date Joined: 25/06/08
Patrols are noisy
Wed, 2009-06-03 14:42
we have 4 here at work - all have periods of squeaks - paticulary when muddy - and the gearboxes are quite noisy - but good reliable vehicles.
JoRn's picture
Date Joined: 20/11/07
Mako, There is a spray that
Wed, 2009-06-03 15:32
Mako,
There is a spray that my dad has at his workshop that you spray. I can ask and get back to you or i can lend you some.
we spray this substance to most cars taht we change brake pads on.
i use to work at his mechanic workshop when i was still at uni.
Colin Hay's picture
Pass the name on if you don't mind JoRn
Wed, 2009-06-03 16:01
I would be interested. Spraying something is about the strength of my mechanical skills (Lol).
deefa's picture
Date Joined: 09/09/05
Yo Mako- you can follow any
Wed, 2009-06-03 17:41
Yo Mako- you can follow any of the advice here (check your brake fluid.....lol), or just call me, Its what i do for a living bro. You still have my number? I'm on hol's at the moment, but feel free to call me and i can make arrangements with the boys to sort it out for ya..
Dan
damo6230's picture
Date Joined: 07/06/08
easy to solve the problem mako
Wed, 2009-06-03 17:48
sell the patrol and buy a cruiser.....ha ha {$lang_emotions_tongue-out}
Why swap
Fri, 2009-06-05 17:58
Why swap vehicles when he is driving the better of the two now???Big step backwards if he did!!!!
deefa's picture
did ya get it sorted Mako?
Fri, 2009-06-05 12:22
finally got it sorted, got
Tue, 2009-10-13 08:38
finally got it sorted, got off my butt and went to an auto store and got a can of CRC De-squeak, just pointed it though the slots in the mags and coated the disk and wamma, no squeaks
Dasho's picture
Date Joined: 24/03/06
I will have to get me a can
Wed, 2009-10-14 07:23
I will have to get me a can of that stuff.  My drivers side brake pad is shitting me BIG time!
yeah im glad i finally
Wed, 2009-10-14 08:42
yeah im glad i finally sorted it, used to hate the squeaks, spewing i never sorted it earlier now
81macca's picture
Date Joined: 02/07/09
BENDIX
Wed, 2009-10-14 08:49
Always machine the rotors and use bendix brake pads and you should be good. I would be very reluctant to put any chemicals or groove the pads as this will cause problems and you wont get the the best braking possible out of the patrol.  No short cuts with brakes!
I actually fish.
Getting all my brakes done
Thu, 2009-10-15 15:18
Getting all my brakes done soon when I get new tyres all the way round on my Outback. Probably get my mobile mechanic to do it as he's the best Suburu mechanic around, used to be a mechanic for the Subaru World Rally Team so he has a fair idea what's going on with them.
Dale
