spare trailer parts when towing distances
hey
i have a spare wheel but  need to get a spare hub for the trailer as intending to start towing further afield . where is the cheapest spot NOR for trailer parts??
Seaquest's picture
Date Joined: 22/10/09
 Martins trailer parts,
Wed, 2010-12-22 06:35
 Martins trailer parts, Wangara
Nimbin 157's picture
Date Joined: 03/05/10
Wed, 2010-12-22 08:42
4 Katanning st Bayswater. Never seen one in Wangara though i could be wrong
alfred's picture
Date Joined: 12/01/07
Bayswater is the main office
Wed, 2010-12-22 09:20
Bayswater is the main office and warehouse.
Auslobster's picture
Date Joined: 03/05/08
BCF and Supacheap...
Wed, 2010-12-22 10:30
...and most likely any other auto parts store certainly carry marine wheel bearings, and usually hub assemblys as well.
The weekend
Wed, 2010-12-22 12:04
Just gone was on the return trip from the ramp when we stopped to drop of the decky and have a quick beer, looked down and one of the outer wheel bearings had exploded and was no longer existant, lucky for the disk brakes holding the wheel on.
So a quick google search on the dunbier site to find the difference between the bearings and such,
I ended up with 45mm axels and the stud pattern is ford.   #$%#$&^*^*
Almost put the boat on the market,
Ended up with a new bearing set at $20 they did have a complete set including stub axle,bearings,cap and wheel nuts for $49.99 which i though may not be a bad idea for a long trip.
Aaron Santos's picture
Date Joined: 12/11/10
Hi brock,Are all dunbier
Wed, 2010-12-22 12:12
Hi brock,
Are all dunbier trailers the same set up with the 45mm axel and the ford stud pattern, im looking at getting mine redone.
ive seen at BCF that there are ford bearings set and holden so just trying to find out what mine would be.
Still trying to catch fish!
West Coast Eagles Supporter and Proud Member.
No
Wed, 2010-12-22 12:28
Some are ford some are holden, not sure how to tell apart but the dunbier site had both types.
When i purchased the boat the bloke told me about the ford pattern and when i done a quick search and check the axel it measured up at 45mm.
My boat is 5.2 so the axle size will vary i would think.
grayzeee's picture
Date Joined: 09/07/09
cheers for the answersjust
Wed, 2010-12-22 13:21
just phoned martins
 apparently there are 3 diff stud spacings
63mm  holden ht
67mm  ford
71mm holden hq
measured from centre of one stud to next (not through axle centreline)
allrounder's picture
Date Joined: 10/11/08
Not trying to throw a spanner in your works
Wed, 2010-12-22 14:37
 but it would pay to have a go at replacing at least one of your wheels bearings.A guy i know had dramas on the side of the road on the way to exmouth because his outside bearing was holden and the inside was ford or it may have been the other way around.Screwed him over either way.
wangler's picture
Date Joined: 26/04/08
Heading to
Wed, 2010-12-22 14:04
Cervantes soon, so just checked all my bearings,springs adjusted the brakes slightly etc. I will be taking 2 spare hubs( 1 new and 1 used), the used one is packed with grease and bearings wrapped in gladwrap, labelled and ready to go, the other new hub just has the cones pressed in, 3 spare dry bearing kits, grease (tub), 5 x wheel nuts, bearing caps and 2 spare wheels with tyres of course. All this for a tandem trailer. Hopefully I dont forget the tools to put it all together ;-)
0.
Dougie
Steve Richards's picture
Date Joined: 10/10/07
TRAILER PARTS
Wed, 2010-12-22 22:02
Last year we did a trip to Ningaloo and took the usual bearings,hubs and spare wheels, but also took a couple of spare springs, good job too coz on the track out of Ningaloo we busted a spring on my mates single axle trailer. A trolley jack on a piece of ply and 20mins later we were on our way. PS  Dont forget the tools to do the job.
strike_zone's picture
Date Joined: 09/09/10
no chinese
Thu, 2010-12-23 00:23
spend the extra money and buy japanese bearings well worth it the cheap chinese ones really are shit
NOHA's picture
Date Joined: 24/06/07
Check your bearings.
Thu, 2010-12-23 10:06
 before any long trip pull off your hubs and check your bearings. If the bearings have been rusty or damaged then damage to the axle is possible too.
I tow long distances and like to carry at least 2 spare hubs with quality bearings already fitted a lubed, in a plastic bag, back in its box. A full spare axle and springs is a good option as well if rougher roads are expected.
Spare rollers are good to have also
No Orange Hats Allowed
