small toolkit for car
Just going to put together a small toolkit for the trip to Exmouth. Without going way over the top, what do others carry in the way of a small toolkit for general repairs on long trips?
I'm not interested in spare hoses, fanbelts, oil, grease or the like - just basic tools I should have (and possibly others making the trek to Exmouth next week).
Tools
Sun, 2009-04-19 15:23
Jack,wheelbrace,mobile phone and RAC membership.With the newer cars around the average person can only change the oil and very little else now days,not like 20yrs back when there wasn't much you couldn't do.
Bottle of oil and 5-10 litres of water.
chevin's picture
Date Joined: 11/04/09
Tools
Mon, 2009-04-20 18:54
Yeah, I used to drive up north a lot and I reckoned that I could deal with anything short of a con rod through the side of the block in my HJ Statesmens.  Now I look under the bonnet and I don't know what I am looking at!Even the mobile phones on the Exmouth run aren't a lot of good because you are out of range for such long distances.
Eagles may soar, but I will never get sucked into a jet engine.
I saw a TV advert for an exercise machine today and it was said that just three minutes a day of the machine would give me the body I dream of.  How will three minutes a day on an exercise machine give me Miss World?
HuggyB's picture
Date Joined: 03/08/08
not so much for car repairs
Sun, 2009-04-19 15:25
but trailer, bearing changes if needed etc.....
BTW, I am taking a hire car up there so if it s**ts itself, I'll be on the phone for a new one!
Tools again
Sun, 2009-04-19 15:31
Screwdriver,pliers,crescent spanner,1x bearing set[inner.outer and seal]and a tube of suitable grease.If you do them before you go they should be more than ok to do the whole trip without any problems
Neander's picture
Date Joined: 23/10/07
Iusually have a set of
Sun, 2009-04-19 17:17
Iusually have a set of metric spanners,a socket set, set of screw drivers, pliers, cutters, adjustable wrench,hammer, 4 size zip ties from small to large.
PilbaraBrad's picture
Date Joined: 16/05/07
hammer, flat blade, pliers,
Sun, 2009-04-19 18:49
hammer, flat blade, pliers, 12" shifter, bearing grease
dosnt hurt to have a spare split pin, i always get the shits with mine pulling them out and need a new one half the time
other handies
depending on make of car metric or imp spanner set 8-24mm
torch, crc, multigrip pliers, cable ties
and a socket set met or imp depending on car
http://fishwrecked-reeltime.com/
Paul G's picture
Date Joined: 12/12/07
fuses,are a must.i have a
Sun, 2009-04-19 19:21
fuses,are a must.i have a large kit on board the boat can never be sure on what you will need to change or fix..
nearly forgot the tool box thank huggyB
Sun, 2009-04-19 19:28
  between us all we should have everything covered
RUSS & SANDY
UncutTriggerInWA's picture
Date Joined: 05/09/08
The Cockies toolkit
Sun, 2009-04-19 19:30
A crescent, a hammer and some wire mate.. LOL
http://vinceholt.spaces.live.com/
Work Smart - Fish Often
Vince.
Work smart and fish often.
HuggyB's picture
Thanks all
Sun, 2009-04-19 19:34
Had a reasonable idea of what I was gonna get, but a few good suggestions that i didnt have as well.
Shopping tomorrow.....
Date Joined: 18/05/08
Depends
Sun, 2009-04-19 19:40
 Depends on wether you have a 4WD or a fwd Tongue outhey huggy
Cheers Uncle Stu
wadetolley's picture
Date Joined: 27/06/08
some blocks
Mon, 2009-04-20 19:08
 some blocks of wood for raising jacks,chocking wheels ect always boggy or uneven ground when you get a flat..murphys law!
IF YOU EVER NEED A LIMOUSINE...CALL LAKES LIMOUSINES BALLAJURA
MOBILE 0416341256 OR PH 92496113
Date Joined: 04/01/09
tow rope, exhaust jack in case u aint on flat ground.
Tue, 2009-04-21 23:09
1.) Highstick 2.) Skulldrag the bastard!
Proud supporter of Oceanside Tackle & Marine and The Tackle Shack
kane's picture
Date Joined: 07/12/08
Being a mechanic i pack more than most people i guess...
Thu, 2009-04-23 09:49
Ive got a good tool bag which holds a 3/8 socket set, metric spanner roll, hammer, pliers, screwdrivers, shifters, 3/8 torque wrench. It all fits in the bag and doesnt take up much space at all.
As for spares i take 2 spare wheel bearing sets for the trailer, and a set of belts oh and a tube of grease.
Also carry a 4x4 recovery kit with snatch straps, shackles, hand winch, compressor (untill in blew up), tyre repair plug kit, spare pre mix coolant and engine oil too.
The trip I just got back from i almost downgraded but was glad i didnt as we had one of those trips where mostly what could go wrong did go wrong and Im pretty sure every tool in the kit got used at some point.
Good point about the block of wood for the jack, helps alot in the sand, thats the one thing I didnt pack and had to borrow a piece of someone camped down the track to stop the jack burying itself in the sand.
One other thing is i keep a gregorys workshop manual under the passenger seat, not much point having all the gear to do a repair if you dont know what your doing, even mechanics need a manual to work from.
But if your not mechanically inclined a good level RAC membership should pretty much see you right.
Goooooone Fishin!
Gooooone Fishin!
