small graphite vs small fibreglass-glasstip rod
eh guys, i'm currently using a 7'6" graphite rod to flick small lures and sp around, however i also have a 7'6" fibreglass rod with glass tip that i was using when i started baitfishing for breams...
which one would achieve greater casting distance with 8lb braid and 40cm of 8lb fluoro? i'm mainly using sps and little minnows
as well which one would better allow to feel the bites?
a last question not relating to rods, any tips on how to avoid weed when using sp's and lures?
thanks in advance for your comments
Colin Hay's picture
Date Joined: 23/10/07
Try them both out and see which one feels better
Fri, 2009-01-30 12:50
I can;t help you too much without knowing more about the specifics of each rod.
Can't help you too much with the weed either. I have had to put my SPs back the bag when bream fishing lately because of the weed.
WODF's picture
Try em both
Fri, 2009-01-30 13:20
try them both as Colin said but my pick would be the graphite, lighter and more sensitive to bites. Nothing much you can do about the weed except hope it goes away
Goodluck
"holy sh!t, did you see that?"
hlokk's picture
Date Joined: 04/04/08
Usually graphite will cast
Fri, 2009-01-30 13:08
Usually graphite will cast further, but if the tip is quite whippy, then perhaps it might chuck a small lure further (as the lure doesnt have a lot of weight to impart rod bending for the cast). Graphite will almost certainly be more sensitive and easier to work the lures/plastics with finesse action. Depends on the specifics of each rod though.
As for weedless, try texas rigging them with g-locks or similar (e.g. twist locks)
Always interested in someone to go fishing with
ody's picture
Date Joined: 30/12/06
Hi Ya, Until early 2008 had
Fri, 2009-01-30 13:14
Hi Ya,
Until early 2008 had only fished with solid tip rods.  While in Kalbarri October, used my brothers graphite and the difference was astounding.  Both rods were 2 - 4 kg, mine with 6lb crystal fireline my bros 3lb braid of some sort.
For me now, graphite all the way.  That is not to say that the solid tip does not have it's place, I simply haven't found it yet.Smile
I suppose the real difference is that with a solid tip, you move your (rod holding) hand in an arch of 45 degrees, your rod tip does not move anywhere near that far because of the 'bend' in the tip so your lure doesn't move far at all.  However, with a graphite, move your hand in a 45 degree arch, the tip of the rod will move a much greater distance because of the lack of 'bend' in the rod, and your lure moves much further.  The down side is that you have to learn how to use lures all over again because if you aren't careful, each twitch of you hand will move your lure several feet rather than the few inches required.  And that will result in much fewer fish.
And I'm still learning. Cry
Cheers.
RECFISHWEST member
honsu chin's picture
Date Joined: 20/09/05
A graphite rod will cast
Fri, 2009-01-30 16:24
A graphite rod will cast further than the equivalent fibreglass rod due to the ability of graphite to respond back with a counter load everytime you cast. At the end of your cast, the fibreglass rod hasnt got much memory, therefore it'll wobble its ass away restricting line flowing thru the guides. To get a further cast, the line has to straightened out quicker, so it'll flow thru quicker hence further cast. A graphite rod has memory and less recoil. So the quicker the rod can straighten out the faster the line can travel thru the guides thus giving you a further cast.
Manager/Tackle Rat @ "Oceanside Tackle & Marine"
364 South Street, O'Connor, Perth Ph# 9337 5682
