Sinking boat
This is over a week. Deisle pissing out. Oil slick for miles.
quadfisher's picture
Date Joined: 28/09/10
Rusty treasures ?
Mon, 2019-06-17 20:13
 Gee theres some floating turds in that area isnt there?
 Oh thats right rust and weathered patina is the in thing A.T.M.
 I have seen another larger white rusty craft in that area , and I beliveve its breaking the laws of physics by floating.
quadfisher
 Looks like time ran out for
Mon, 2019-06-17 20:33
 Looks like time ran out for Timeless...
Agree
Sad. Guy must work away maybe?. Been slowly sinking for over a week. On bottom now motor everything will be stuffed. Plenty off good snapper wrecks or dive wrecks in area.
Shame to see that
Mon, 2019-06-17 23:14
Timeless was quite a good Rotto boat and used to be owned by my father in law (now deceased rip)
ranmar850's picture
Moored boats become neglected
Tue, 2019-06-18 07:45
 They are expensive to keep up, people can't afford it, or their health is suffering, can't get out to look at it, no-one else helps...sad but true. I always try to steer people new to boating away from mooored boats when they are looking at them, for those reasons. You can't sink something on a trailer...larger boats on moorings are the proverbial hole in the ocean, which you try to fill with  money.
Moking's picture
Date Joined: 30/05/12
 Yep- I was out there
Tue, 2019-06-18 08:44
 Yep- I was out there squidding yesterday, and could smell diesel,and I could see the diesel slick on the water. I was quiet a distance from that boat.
Moved away from the area!
pelagicyachts's picture
Date Joined: 23/02/11
Steel hull, sat in the water
Tue, 2019-06-18 13:10
Steel hull, sat in the water with out maintenance..... what could possibly go wrong
I would have thought the council/dept of marine and harbours would be on to that - should not be allowed to sit their bleeding out oil and fuel
Moking's picture
 I would of thought that as
Tue, 2019-06-18 13:15
 I would of thought that as well...but it is Rockingham! lol
The "wheels turns slowly" down here......
Stevo81's picture
Date Joined: 16/04/12
DOT will engage commercial
Tue, 2019-06-18 14:36
DOT will engage commercial operators to salvage the vessel and then attempt to recover costs from the owner is the way it normally works. Preferably quicker than what is happening in this situtation
dmck's picture
Date Joined: 07/03/19
inboard/outboard are trouble..
Tue, 2019-06-18 13:16
 The seals around the outboard/transom are usually just a rubber type fabric and they perish.. A little leak lets in a little water for a long time and the back of the boat settles deeper.  More water pressure on the seal... a bigger leak and down she goes.
This happened to my mates 32ft Skippercraft but luckily we were away on a trip and saw it getting lower in the water.
Got her back to shore PDQ and on the trailer b4 disaster happened.
lots of scenarios but the
Tue, 2019-06-18 13:46
lots of scenarios but the most likely would be the batteries died - solar panels trickle charging batteries cause lead acid to bubble - over time the bubbling causes the acid to evaporate until the battery is no longer effective - slow leak or that heavy rain fills boat, once a skin fitting or exhaust is below water line its all over pretty quick....
Manfish's picture
Date Joined: 24/11/18
  Sounds simmilar to the
Thu, 2019-06-27 18:15
  Sounds simmilar to the seals around the prop shafts (stuffing box) on the shaft driven boats.Cheap and easy fixes,but they will sink a boat for sure if left to fail.
Date Joined: 28/11/16
I used to salvage these
Tue, 2019-06-18 20:46
I used to salvage these things all the time a couple of air bags and throw in a pump and she’ll be up in a jiffy
I hope so
Tue, 2019-06-18 23:42
Id hate to see a boat that I have good memories of come to an end like this.
 its a shame to see an old
Wed, 2019-06-19 17:22
 its a shame to see an old tub like that . hope it gets resurected before its stuffed
scottnofish's picture
Date Joined: 28/08/07
would have been the
Thu, 2019-06-20 15:07
 extra ton of bird crap on it that sunk it .I have a laugh every time I drove past it as to how much crap was on it
Fair few out there
Thu, 2019-06-20 17:24
Where you hold your Breath as you drive past .
Does anyone know
Thu, 2019-06-27 17:21
Does anyone know if timeless was raised before this latest stormy weather set in. Rockingham is notorious for having boats washed a shore when the weather gets a bit gnarly.
Fully down
Fri, 2019-06-28 07:37
Still there . It s still moored.
axey45's picture
Date Joined: 26/11/13
  bit slow to late.
Sun, 2019-06-30 16:46
  bit slow to late.
Early on this week it got re floated
Thu, 2019-08-01 18:49
Seen mooring guys lift it up . Funny story ,one of the guys I work with( was his brother in-laws) he gave it away for free . Lots needs to be spent now. Good mully wreck would be all it’s good for now imo
axey45's picture
 Should just tow it out in
Fri, 2019-08-02 05:21
 Should just tow it out in dark and ooops.
Moking's picture
 I noticed yesterday,there's
Fri, 2019-08-02 05:41
 I noticed yesterday,there's another one (about same size) has also sunk on it's mooring.
Sitting about same height in water,attached to mooring.
