Seastar Hydraulic steering parts
Submitted by PilbaraBrad on Sat, 2010-08-14 22:22
Today i blew a seal on my seastar hydraulic steering cylinder. I have located a few places in the states that sell the seal kits for about 100US. Does anyone know any one in AUS that sells cylinder seal kits with the special spanner for a seastar HC5345
if anyone has any info or has experienced this in the past would appreciate any info
Brad
maybe contact the maker of
maybe contact the maker of your boat or maybe all boat business
greasemonkey
Date Joined: 08/05/09
Transeals
Try this mob http://www.transeals.com.au/welcome/index.html
They have always been able to match up any seal or o ring I have needed
PilbaraBrad
Date Joined: 16/05/07
this is what i am looking
this is what i am looking for, cheapest is $135 but from the US, if i can i would like to try and support one of our site sponsors except no one has them listed anywhere. Seem like they are pretty hard to find in AUS
ill give it a week then to the US I go i suppose
http://www.iboats.com/Seal-Kit-For-Outboard-Front-Mount-Cylinder-W-Tool-Teleflex-Marine/dm/cart_id.768498400--session_id.847127703--view_id.169604
whaler73
Date Joined: 25/07/10
call hayway marine
a friend of mine just got one thru hayway marine they are distributed locally by bla part number 293714 a bit dearer to get in australia rrp $217 but they do give disc if you ask nicely and you dont need to worry about getting ripped off by someone from the otherside of the world
MILF (MAN I LOVE FISHING) MILF
When comparing part prices,
When comparing part prices, I've always found Challenge Marine much better than hayway.
Bits
If you can get the top off take the seals into Coventry's or any other seal/bearing shop up there and they will be able to find a match for them at a fraction of the price.
The spanner thingy looks like one for your disc grinder, may have to make one up to suit the unit.
dodgy
Try CBC bearings for the
Try CBC bearings for the seals brad.
PilbaraBrad
cheers yepthe spanner is
cheers yep
the spanner is the same as a grinder (pin spanner) just a different size to any grinder i have or have seen(typical), that is the cheap bit anyway can get one for $5US
dont have a lathe which i would need to turn up a tapered fitting to get the seal over the threaded section of the cylinder
will probably order fromt the US got a mate who has ordered from the same shop and had no dramas. I think once i have the seal in my hand i will take it to the seal shop to get a few spares, that way i have all the tooling i need for any next times.
still a lot cheaper than AUS or replacing the whole cylinder should be able to do it for $130, next time probably only about $25
whaler73
no challenge
i disagree totally with you till i would never set foot back in challenge marine again burnt too many times hayway are much superior for expertise service and most of all price you just have to know how to deal with people
dodgy
Good to know. I have a
Good to know. I have a warrenty issue to take up with Hayway in the next couple of days.
Bodie
Date Joined: 05/11/07
whats the cost of
whats the cost of replacement of the cylinder?
I replaced mine about 12 months ago, was only about $300 for it.
PilbaraBrad
$300 for a HC5345? where is
$300 for a HC5345? where is that?
anyway 300 bucks v's 130 which will make mine as good as new, its a no brainer
ordered today will be here in 5 days
i know i should try by aus but 217 plus postage v's 124 delivered to my door, looks like my dollars go to propping up the US economy. Even so, the local distributer purchases it from the US anyway, just with his bit on top.
PilbaraBrad
Well it only took two weeks
Well it only took two weeks to get the parts here from the US and I am as of this afternoon back in business
one functioning hydraulic steering unit again, woo hoo!
smelly62
Date Joined: 02/09/11
Does anyone know if the seal
Does anyone know if the seal kit is better than original because after only one season the ram is leaking badly from both sides. If not then I might change brands.
Sulo
Date Joined: 13/08/11
It will depend on how much
It will depend on how much wear is on the actual shaft. If the shaft is worn and not just the seals then a seal kit is not going to fix the issue.
sarcasm0
Date Joined: 25/06/09
It depends on maintenance
As said above, if the ram is scored or marked it will cut out the seals. Most important thing is to wash them down after each use, clear off any salt and then dry it out. If left wet dust and crap can adhere to the ram and cut the seals the next time the ram moves.
At nearly $300 for a seastar seal kit and approximately $450-500 for a seastar ram or $600 for a hydrive ram you have to wonder if the seal kit is worth it.
