Scrubber valve Quintrex Sports
Does anyone know the orientation of the rubber flap on the Scrubber valve on Quintrex Sports ? I've install new valves with the rubber flap facing downwards (6 o'clock ) I'm still getting lots of water in the hull and wondering if I have installed the rubber flap in the correct position face down ?
searched the Net with no joy
Ledge64
I have always seen them
Sun, 2024-03-17 14:43
I have always seen them installed the way you have. Not good that your still getting water in like that . I did have solid spring loaded ones with rubber seals in which still leaked a bit
 Ihave a Quinnie Ledge and
Sun, 2024-03-24 13:02
 Ihave a Quinnie Ledge and sounds like you've installed correctly. Have you checked the hoses etc?
