Road between Lancelin and Cervantes
Submitted by Lucky Tim on Fri, 2010-01-29 21:00
hey guys. We're heading to Jurien for the night on Saturday. My old map has the road between Lancelin and Cervantes as a dirt road. Is this still the case and if so, is it worth driving (in a Navara 4wd, just can't be bothered if it means getting beaten up for 75km). Or is it best to head back to the Brand and around that way?
Tim
tournament
Date Joined: 10/11/09
done them earthworks for
done them earthworks for that road back in1996 so unless its been used it could be a bit over grown
better off sticking to the
better off sticking to the black stuff. much smoother ride unless you want the scenic route
hlokk
Date Joined: 04/04/08
Arent they putting in a new
Arent they putting in a new road now? (at least to wedge atm, leveled but not surfaced, or mostly surfaced but closed?).
When I did the route I went kinda NE from lancelin (instead of due E, and slightly south). Seemed a bit shorter/quicker than the other route (forget the road name).
Lucky Tim
Date Joined: 28/11/07
cheers guys, might head back
cheers guys, might head back out to the highway just to make sure.
Nauti Buoy
Date Joined: 20/04/09
Coast Road
The lancelin to Cervantes stretch is currently under construction- I'm pretty sure it is supposed to be completed by around April this year (don't hold me to that) until then use Brand Hwy. It is going to make Jurien, Leeman etc a bit closer for the metro crew.
Lucky Tim
Thanks for that, I saw the
Thanks for that, I saw the new road going in, the public access/bitumen part stops just south of the Pinnacles.
