Restoring weathered boat canopy clears?
Submitted by mjohns on Tue, 2014-04-15 17:49
Anybody have any ideas on how to clear boat clears that have been in the sun for a long time?
Bubbled and burnt around some edges, and can no longer see through them?
Not looking to get them perfect but a bit of vision through them would be great?
Or is it a case of replacing them?
Thanks - Mick
PJAY
Date Joined: 12/05/09
try some mr sheen and a soft
try some mr sheen and a soft cloth but sounds like they may be buggered?
mjohns
Date Joined: 11/01/07
Will try that thanks mate,
Will try that thanks mate, yeah i think theyre pretty far gone..
Worth a shot anyways ta
Michael Yoni
Date Joined: 02/01/11
go to detailers
go to detailers paradise.com.au and ask the question there. They may be able to recommend some compound to clear it. They have done somilar things with plastics and glass.
yeah if they are physically
yeah if they are physically damaged nothing short of a repair will do it.
Having said that mine were a bit weathered also and I used Mothers plastic cleaner(or restorer?) from the auto shop and came up a treat.
Lay them on flat ground and follow the instructions
freoboy
Date Joined: 09/05/11
There is a specially
There is a specially designed product called Plexus, comes in a spray can, seems to work ok
ace rimmer
Date Joined: 19/08/13
plexus
I use PLEXUS on mine it is a cleaner and also soften's them, but if they have gone milky from the sun you will need to replace them
Grumpysmurf
Date Joined: 26/02/09
Plexus works well if they
Plexus works well if they are still in good shape. If they are already bad, as a last resort which works really well for me is household JIF.
Haines Signature 610C with Mercury 150 EFI
