Rain water in boat.
Submitted by Manfish on Tue, 2019-06-25 20:36
I keep my half cabin boat raised and fully covered by a water proof boat cover. But after it rains I find about 3 ltr of water pooling inside, down the rear of the boat.The boat is utterly covered and there are no holes or tears or anywhere the rain can breach the cover... how is this happening?
piston broke
Date Joined: 05/11/08
Get
under the cover and find out
Manfish
Date Joined: 24/11/18
I did that a minute ago
I did that a minute ago while it was raining.The inside of cover does have a moist/ wet feel to it but no dripping.The water must be seeping through real slowly.
Trailcraft570
Date Joined: 06/11/13
That’s exactly what happened
That’s exactly what happened with mine after a couple of years of use and exposed to Sunlight/UV etc. The water works it’s way through the fabric and with gravity will make its way to the lowest point of the cover which I am guessing is probably the back of your boat.
Sea goat
Date Joined: 26/03/17
i would think eiuther a leak,
i would think eiuther a leak, or condensation??? not sure if would account for that much though....
Hose
Get someone to run a hose on it while you are underneath then rub where the water is hitting the cover, you will more than likely find it comes through the fabric
Manfish
The storage bag it came in
The storage bag it came in is made of the same material.I filled it with water once and it did'nt leak a drop, it's water tight.
Trailcraft570
Cover
if it’s an older “water proof” one, it’s probably water repellant and will still let water through if subjected to enough heavy rain.... I’ve had the same problem previously with fabric covers that were meant to be water proof. They lose that proofing after a few years
Manfish
It's fairly new, off ebay.
It's fairly new, off ebay. It's also water proof and holds water well, this is why I'm puzzled.
Brock O
Mine loves the winter fresh
Mine loves the winter fresh water wash..
scubafish
Date Joined: 15/08/12
Just suggestion
If it is the blue canvas that the canopy's are made of I think you will find it is water resistant
not water proof Unless the bottom side is dry.If it is soaked through (water resistant)
Any parts touching the canvas (water resistant one) it will leak through the canvas.
This is what happens to my canvas canopy.It wont come through when it is tight ,but does get totally soaked and when you touch it the water comes through.
Possible Problem.
maldugs
Date Joined: 10/11/15
cover
Hi I bought a silver coloured tarp from Bunnings, covers the boat completly held down with occy straps, does the job fine.
Mal
