parts for 350 chev
could anyone tell me the best place to look for a starter motor for a 350 chev, dont have the $ at the moment but its good to know where to look. Chevpower can do one for $280.
Also apart from a heavy duty marine battery , what battery could be good for the 2nd battery in the boat
Date Joined: 30/12/08
You don't need
Thu, 2010-02-04 07:30
an expensive marine battery as a back up in your boat Russ. A heavy duty type of 4x4 battery will do you, about $140 at goodchild batteries Jandakot. Your big boat won't pound to much if at all and as you know a 4x4 can take shit loads of hammer.
kempy's picture
Date Joined: 28/05/09
just a standard n70 should
Thu, 2010-02-04 07:58
just a standard n70 should be fine which are bout $180 wich are 660cca
Rod P's picture
Date Joined: 20/05/08
Got mine from Autospark in
Thu, 2010-02-04 14:46
Got mine from Autospark in Joondalup. Ask him and he will water proof them aswell. I think i paid around $240 ish..
You'll need to know if its parrallel of offset mounted. I may even have one here that i think is Parrallel. let me know which one your chasing.
tailor marc's picture
Date Joined: 27/09/06
Chev power or west coast
Thu, 2010-02-04 15:34
Chev power or west coast chev :)
thanks guys for the
Thu, 2010-02-04 22:25
thanks guys for the info.
Rod P. thanks for the heads up oin that place will look into it , def needs to get water profed as that is the prob. when you say offset what do you mean by that , as the 1 i have has both bolts down near the fly wheel but 1 is higher than the other, bottom one is a pain to put in as its all by feel and limited spanner room
T M , tried chev power and they want $280 ,
the 4x4 battery or the n70 might be the go
Pretty sure I have an offset
Fri, 2010-02-05 15:18
Pretty sure I have an offset here too somewhere.
My skiboat runs straight.
Lastchance's picture
Date Joined: 02/02/09
Starter motor action
Fri, 2010-02-05 17:01
Try Southside Engine Centre or A1 high performance etc as they build high performance Chevs that generally require a high torque starter to replace the old unit - if not they would probably be able to point you in the right direction. Good luck
