Oil leak
Well i just got my holden rodeo lx 1998 serviced the other day to find that it is leaking oil from the front and rear crankshaft seals. I wasnt given a quote so I was just wondering if anyone could tell me the approximate value of getting it repaired.
cheers guys
kempy's picture
Date Joined: 28/05/09
not cheap because the
Sat, 2009-08-08 20:39
not cheap because the gearbox will have to cum out
Hicko's picture
Date Joined: 09/02/08
Oh great, do you know what
Sat, 2009-08-08 20:44
Oh great, do you know what kind of price?
poida's picture
Date Joined: 08/08/05
rodeo oil leaks
Sat, 2009-08-08 22:00
v6, 4 diesel or petrol
pretty sure you can not get the sump off without removing the entire engine. Personally would not do front or back seals without doing the sump at the same time as any future leaks will be blamed on the sump which is probably half the problem atm.
Pull the motor or don't bother.
I personally would wait for the clutch to go, then pull the donk and do the seals or wait until it implodes
kempy's picture
best thing is give auto
Sun, 2009-08-09 06:22
best thing is give auto masters or sum 1 like that a ring they should be able to work out a price through their computer and then make that the most expensive u should have to pay.
Hicko's picture
Its a 4 cylinder 2.8 diesel.
Sat, 2009-08-08 22:04
Its a 4 cylinder 2.8 diesel. Thanks for the info
its only a holden so just
Sun, 2009-08-09 09:16
its only a holden so just let it die in peace, jk , be verry carefull when your getting work like that done as there is a lot of mechanics out there that will charge you a lot more than they should when it comes to the labour side
Big Fella fishn's picture
Date Joined: 04/05/09
Sell It
Sun, 2009-08-09 10:03
And buy a Hilux or Cruiser
7739ian's picture
Date Joined: 25/06/08
then
Sun, 2009-08-09 10:13
a couple more oil leaks won't matterLaughing
synthos's picture
Date Joined: 23/06/07
speaking off
Sun, 2009-08-09 18:02
I still got my nissan patrol I want to get rid off - no oil leaks 89 tho but a good ride :)
