No satellite signal
hi fellas,
On sat morning I took the boat out to try my new sounder.  The sounder works great though for some reason my GPS is playing up.
Usually when I turn it on after a couple of minutes it detects all the satellites and it fires up. However, yesterday it stayed on the "acquiring signal" screen when occasionally a satellite would appear then drop off the screen.  After an hour or so I gave up.
When I got back I tried restarting the GPS and resetting it back to factory settings though I'm still getting the same problem.
The sounder I have is a Navman 5380.  I was wondering if anyone else has experienced a similar problem?  Or perhaps have some suggestions?
If I can't get it working then I'll take it back to Challenge Marine though hopefully I can avoid that.
Wayne
harro's picture
Date Joined: 07/02/08
everyone
Sun, 2009-10-18 17:54
dunno bout the navmans mate , i used to own a 5500 but atm lots of pple including me are having trouble with modules with the lowrances.
wheres ur ariel, is it integrated? if so it may be bouncing back off the metal surounds,
that has happened to me before,
 :::: Bass Hunter ::::
wayneleech's picture
Date Joined: 27/06/08
its an external aerial which
Sun, 2009-10-18 18:19
its an external aerial which is mounted just up behind the GPS - in the corner of the console.  here's another pic showing where the aerial is.
Do you think the new sounder could be interferring with it?
Matt T's picture
Date Joined: 19/11/07
What dog?
Sun, 2009-10-18 18:49
Beautiful looking dog mate, great coat.
8120 does it occasionally
Sun, 2009-10-18 19:11
I spray the antenna plug with inox regularly and, additionally, if you still have problems go into the sat menu - for some odd reason ours occasionally decides not to use some satellites - appears to be voltage spike related as we note it when the batteries have been a little flat after a long layoff.
In the menu you can tell it ito use the sats and it immeidately acquires position and then doesn't happen again for months
its a navman thing, mine has
Sun, 2009-10-18 19:15
its a navman thing, mine has do it in the past.
a restart usuallyt fixes it.
also was told if its possible get a power pack and run it at home 24/7
the units like being warm.
allrounder's picture
Date Joined: 10/11/08
you will find if you
Sun, 2009-10-18 20:22
turn your sounder of your gps will work if this is the case your arial is to close to your other electrics .I had the same issue on the polycraft.Moved the arial about a foot and it was all good after that.
my dog is a weimaraner - it
Sun, 2009-10-18 20:33
my dog is a weimaraner - it was his first time out so he's still finding his sea legs;)
Cheers fellas - I will try all that has been suggested.  allrounder - you could be onto something as it has only started playing up since the sounder was installed...
Bluebonefamily's picture
Date Joined: 15/08/09
nice dog
Mon, 2009-10-19 16:27
We have a weimaraner too named Mal.  We have never taken him on the boat.  He is 11yrs old now and likes his comfort.
Mal is a really nice good tempered animal.  He coped well with the expanding family and loves giving the kids a big lick.
Member of Cockburn Power Boats Association
i have 2 gps units sitting
Mon, 2009-10-19 05:13
i have 2 gps units sitting right next to a 585 sounder and i have never had that prob unless it has something to do with the alli dash they are siting on, have you checked that there are no damaged spikes in the plug that goes into the sounder as that has happened to me
it wont be the fact
Mon, 2009-10-19 05:20
that the sounder is near the gps it will be that the arial is near the sounder.I am guessing that your arial Russ is away from the units.
i have 2 gps's on the boat ,
Mon, 2009-10-19 18:53
i have 2 gps's on the boat , one has built in arial right near the sounder and the other on the roof and never lost signal on either, only when i had a damaged pin on one of them
you have done
Mon, 2009-10-19 19:03
well.
hehehe The Weimaraner
Mon, 2009-10-19 10:43
looks like he's about to decorate the boat floor with his breakfast !!!
Tandawg's picture
Date Joined: 13/02/07
gps not fixing
Mon, 2009-10-19 13:27
Hi Wayne, I fished a fishing comp on Saturday and my mate also had the same problem with his Garmin GPS not aquiring sats. Bit strange though as everyone elses GPS worked.
Regards
Chris
Date Joined: 27/02/08
My Navman has had times when
Wed, 2009-10-21 09:03
My Navman has had times when it was slow to pick up a signal ............. as some one stated above usually the old off/on trick fixes it. After all it is just a computer and the off/on button fixes ALL computer problems.
Sounds obvious but make sure that the aerial is covered over by a bit of rag etc
Steve
hi all - just to let you
Thu, 2009-10-22 22:10
hi all - just to let you know that it turns out is was a stuffed aerial!  I took it down to challenge marine and they put a new aerial on it and it worked fine:)  We put my aerial on another machine and that wasn't working either.... glad to have it fixed:)
btw steve, what do you mean when you say make sure the aerial is covered by a bit of rag?
Sorry Wayne - it should have
Fri, 2009-10-23 08:13
Sorry Wayne - it should have read "ISN'T covered up"
My mistake
harro's picture
lol
Fri, 2009-10-23 19:40
did the dog throw up....
kane's picture
Date Joined: 07/12/08
tail between his legs
Fri, 2009-10-23 20:07
not happy jan! hahaha
Gooooone Fishin!
haha - na, here's another
Sat, 2009-10-24 17:32
haha - na, here's another pic of him a little happier;)
