I think that they have a known problem with their clutches in that model, I have a d22 and when I bookek into the mechanic he was relieved that I did not have a d40 and he worked at nissan for a couple of years. I would read up and if it has blown at very low mileage complain and see what happens.
Just sent the mechanic the details so that he can give you a quote. He is a Land Rover trained mechanic and worked in Oz for Nissan for a couple of years, knows what he is doing and is honest.
The supervisor beat me to it, but here's what I found out awhile ago regarding replacement heavy duty clutch kits for a D40 Navara.....I checked it out before my son bought his in 2010. At the time, the cost of the HD clutch kit was $1120 + fitting. Now I've got a Nav, too, so I'd be going this way if/when either of ours needed replacing in the future.
The guys were very helpful when I was enquiring about their kits.
Clutch Industries Unit 7, 32 Robinson Avenue Belmont WA ph. 9277 7055
ive just had this installed on mine at 126,000kms and be done with the Dual Mass Flywheel. $1800 including fitting of the 4Terrain Clutch Conversion. Condition report from mechanic was it was 90% gone so lucky sorted before completely burning it out.
This isnt just a D40 issue. It appears to be a problem with most CRD 4wd's with manual gearboxes to make them feel more car like. A mate had his hilux done in under 50000km's.
i would be looking for another mechanic. you only want your car fixed , not to pay his house off as well. i know mine was a bit older (2004) but i got mine done for $1100 .def look around
snapper
Date Joined: 09/02/08
Google D40 Problems
Assassin Land Based Fishing Club Member
sammy85
Date Joined: 31/08/10
I am on my third 1 stock one
I am on my third 1 stock one gone and 1 heavy duty gone. And at the time wasn't even towing a boat or work trailer
axl100
Date Joined: 06/11/10
I got a quote from nissan A
I got a quote from nissan A new clutch kit is $2975 plus $1987 for a new dualmass fly wheel if its stuffed plus fitting...
woody
Date Joined: 27/02/08
Mate I'd be getting 2nd a nd
Mate I'd be getting 2nd a nd 3rd quotes!!! $5000 for a clutch job is INSANE!!
thesupervisor
Date Joined: 10/06/09
here you go and say 1 day to
here you go
and say 1 day to fit it lets say $600 for a shop to fit it
all up $1700
http://www.ebay.com.au/itm/Nissan-Navara-D40-2-5L-TDI-5-6-Spd-12-05-Heavy-Duty-HD-Clutch-Kit-Flywheel-/270932735620?pt=AU_Car_Parts_Accessories&hash=item3f14d97684
http://www.ebay.com.au/itm/NISSAN-NAVARA-D40-TD-NEW-FLYWHEEL-CLUTCH-KIT-/260750295649?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cb5edc261
snapper
HI MATE
axl100
ok cheers mate
ok cheers mate
r.gates
Date Joined: 15/11/10
4terrain clutch kit
G'day axl
Clutch Industries
Belmont WA
ph. 9277 7055
http://ciperformance.com.au// and click on the online catologue to make sure you get the right one for your Navara.
Hope this helps.
regards
rusty...
Busted Arse
Date Joined: 02/07/10
axl100
Cheers Rusty
Rusty
botti
Date Joined: 24/04/10
Clutch kits
Hey mate give clutch brake Australia a call they can supply excedy h/d kits most likely with out the duel mass flywheel 1300720728 there in malaga
greasemonkey
Date Joined: 08/05/09
ROCK AUTO
http://www.rockauto.com/catalog/raframecatalog.php
I have brought alot of parts from these guys in the US . They are awsome for most things . Navaras are called Frontiers over there .
JOEL
