Navionics Gold in Humm 798ci problem
Hi guys
Yesterday went out and the Plotter suddenly defaulted to an auto map function, which I suspect is the basic map in the unit. Showed no nav markers or underwater structure/contours, and was as usefull as a nun at a party.
Question is do the Navionics Cards fail, should I get a new one, should I swap the storage card and nav card to other slot (ie swap them over) etc.
Any help appreciated.
Neels
snappermiles's picture
Date Joined: 05/11/10
my hds does this from time to time
Sat, 2012-06-02 10:00
just pull the card out and put it back in it works for me!!
heers mate
Sat, 2012-06-02 10:22
Ill do that. Didnt do it on the boat because I am blind as a bat reading wise and it was dark. Didnt want to root the whole kit but will give that a go.
Neels
Date Joined: 22/07/10
 Needs do you have the lock
Sat, 2012-06-02 11:59
 Needs do you have the lock out tab engaged on the card. I've got a998 and have the tab out so no info gets recorded on to it.
yes mate i have
Sat, 2012-06-02 13:46
but whenever the unit wants to write to the card it asks because it can damege it.
By the way, above trick appears to have worked.
Cheers Guys
Date Joined: 24/02/11
Card
Sun, 2012-06-03 05:33
Happened to on hsd10 remove the other card leave out or replace look for tarnish colour on the spare card
