Mobile mechiac sor motor isnt pumping water out the top
 hey fellas took boat out weekend and on way home noticed it wasnt pumpin water out the top nor when we flushed it
rayzor23's picture
Date Joined: 30/01/12
Impellor
Wed, 2013-09-11 15:19
 Would not run the motor mate until checked , Will do serious damage
If your looking for a mobile mechanic Try Sonny The Marine Doctor,Helped me out answering my questions
MattMiller's picture
Date Joined: 15/06/09
Have you
Wed, 2013-09-11 15:43
tried shoving some heavy mono (200lb?) up the telltale just incase it has a blockage?
Common problem
chris raff's picture
Date Joined: 09/02/10
Did you adjust your muffs ,
Wed, 2013-09-11 15:47
Did you adjust your muffs , sometimes mine can be temperamental not getting enough pressure up ..
or blow low pressure
Wed, 2013-09-11 16:48
air down the tell tale,sometimes sand or grit block the system
jayce's picture
Date Joined: 10/12/11
Pinjarah Marine Service:
Fri, 2013-09-13 07:25
Pinjarah Marine Service: 0427836621 His names Scott.
