Max # of Rods allowed in use per fisho.....
Submitted by chris raff on Wed, 2010-05-12 09:52
Hi people ...I usually have a set line out and also baitcast with another ...being two in use...however on the occasion I've noticed others having two set lines out and also fishing with another being 3 in use...I always thought 2 was the max can someone clarify the regulations for this ...thanks Chris
dtr
Date Joined: 12/08/07
Hi Chris, I believe it is
Hi Chris,
I believe it is two for boat and shore based?
Dan.
Nimbin 157
Date Joined: 03/05/10
yeah i always thought it was
yeah i always thought it was 2 as well.i cant see the the point in using anymore for the simple fact that you can only keep your bag limit anyway unless its catch and release and even then 2 is plenty.
bulla
Date Joined: 11/05/10
i believe 2 rods is the
i believe 2 rods is the limit.a total of 4 hooks in total.not 4 sets of gangs
Stop complaining and get on with it !!
chris raff
Date Joined: 09/02/10
"4 hooks in total"
....I sometimes have two separate hooks on the set line and a small gang of three on the other...that be five in total...so i assume thats one too many then...yeah i thought it was only two rods ...thanks for clarifying that guys
cuthbad
Date Joined: 22/04/09
I was under the impression a
I was under the impression a gang counted as one with a maximum of three per rod?
So in theory you could use a gang plus 2 single hooks on one line? not a rig Ive used but thought this would be ok?
DieHard
Date Joined: 06/10/08
Its any amonted ganged and 3
Its any amonted ganged and 3 hooks per rod.
Oceanside Tackle
Date Joined: 23/07/09
The rod count is correct.
The rod count is correct. Max of 2 rods in use at a time and max of 3 sets of hooks per rod/rig. A set of gangs is one hook, doesnt matter how many are ganged up.
Oceanside Team - Specializing in Jigging for demersal, Super Deep Fishing and Cockburn Sound Pink Snapper.
Don't forget to ~ Like us on Facebook ~
Phone #(08) 9337 5682 - Shop 4/364 South Street O'Connor - OPEN 7 Days
bulla
i have all the fisheries
i have all the fisheries catch guides at home.when i get in from work ill dig them out and notify you all on what it states. ps. im a new member to this site and think fishwrecked is great.keep up the good work!
Leemo
Date Joined: 22/02/07
yes, it is 2 rods in use at
yes, it is 2 rods in use at once, and 3 hooks, as oceanside said. does a snell of hooks count as one set aswell?
bludgin' since 94'
DieHard
as far as i know it is
as far as i know it is seperate because you are joining it with a space between were as gang is eye to eye.
honsu chin
Date Joined: 20/09/05
No....snelled hooks are
No....snelled hooks are counted as one....its just another way of linking hooks together.
bulla
the fisheries guide states
the fisheries guide states ;recreational anglers can have a maximum of three hooks or three gangs per line.shore based anglers may use a maximum of 2 fishing lines.rods or lines must be attended.
Alan James
Date Joined: 30/06/09
Does a snell of hooks count as one set?
Don't quote me but I would think two hooks snelled on one trace would be classed as one set. However if you were to snell a dozen or so hooks together on the one trace I am sure that would be seen differently though, which makes it an interesting question.
chookc
Date Joined: 07/01/10
fishing from land jettys etc is maxium 2 rods or handlines and m
must be attended with max 3 hooks or 3 gangs per line.
No limit on rods reels from a boat just the number of hooks per line...
Althought I do know in QLD there are boat limits on the number of rods alowed on board.
chris raff
I would've thought max rods
I would've thought max rods would be same on boat...and if a gang was classified as one hook in theory... I suppose you could have.... 8 x 6/0 hooks ganged on a gardie as bait..surely there must be a max you can have ganged ...
honsu chin
your links of hooks will
your links of hooks will only be as long as your bait, so I dont think its gonna be an issue. Im sure there's no one out there who would use an eel and bait it on a looooong set of gangs or snelled hooks.... be a bit more realistic....
chris raff
" be a bit more realistic. "
no one ...other than you mentioning eels...the example was a garfish and its a legit question about the # of hooks on a gang ...to ascertain whether there was a definitive amount ...at this point it seems there isn't
Bungel
Date Joined: 12/10/08
And IGFA rules?? I
And IGFA rules??
I believe 2 hooks per rig/ per rod is the limit. A treble hook is counted as 3 hooks. All must be fixed, no sliding hooks.
Just thought i would add that as im not a fan of gang hooking. 2 hooks is more than enough.
flangies
Date Joined: 11/05/08
That doesnt even make sense
That doesnt even make sense lol. What about all the breaming lures with two sets of trebles, doesn't that mean it has 6 hooks?
Bungel
http://www.igfa.org/PDF/Inter
http://www.igfa.org/PDF/InternationalAnglingRules09.pdf
Seems that trebles/gangs are considered to be 1 hook, but are only legal to use on plugs/poppers/rapals. Odd, i always understood them to be classed as 3 hooks.. as there are 3 hooks soldered together. Have fished a few comps in the past that allow a max of two hooks only and require lures to also be fitted with only a single double hook or two single hooks.
Leemo
ummm, think your wrong on
ummm, think your wrong on the treble mate. should be counted as one hook. as flangies said, all bream lures and lures in general with two sets of gangs would be illegal if that was the case.
gang = 1 set
snell = 1 set
treble = 1 hook
bludgin' since 94'
the rules are land based a
the rules are land based a maximum of 2 rods are allowed. and from what i have read and heard from many sources the max number of hooks you can have is 3 sets of hooks, so if you want to run 3 sets of gangs that is ok but a bit mad
. that is the reason that the baitchaser rigs are now set at 3 hooks unlike the older ones that had 10 hooks, you can still get them but are illegal to use
flangies
Well said , And another
Well said , And another reason why i recommend the mustad packs that come in two sets of 3 baitchasers, and doesn't need modifcation, has sinker loop and swivel at top as normal
dagree
Date Joined: 08/12/07
Straight from the fisheries website
Page 15 of their pdf download.
Fishing gear
(FRMR Part 4A, Division 2, Regulation 64C, 64E)
Rods, lines and hooks – Recreational anglers may have a
maximum of three hooks or three gangs of hooks per line.
Shore-based anglers may use a maximum of two fishing lines.
Rods and lines must be attended.
http://www.fish.wa.gov.au/docs/pub/WestLimits/westcoast_rules_2010.pdf
But I admit it does not answer all questions which doesn't surprise me. It is the same as any reg or standard (Open to interpretation)
) with a maximum of 3 "hooks" whether single, ganged or snelled( I would argue that the maximum hooks allowed would be a combination of leaders and not the way they are set up.)
Doesn't make mention of maximum lines from boating and doesn't specify meaning of ganged hooks....
My Interpretation is that I am allowed 2 lines per person FROM SHORE (Anyone would be crazy to have more from a boat unless they are on a big one
I am sure I will be corrected if wrong
Cheers'
David
Cheers,
David (AKA Grumps)
Location: Heathridge. Toys: 120 Series Prado ... 5.3 Stacer Seamaster/Merc 90HP.
