Loosing power
Submitted by grahaml on Sat, 2016-04-23 11:43
hey all
l have a issue that's developed with my 60 merc and i hope some one may have a suggestion on a fix .the outboard starts easy as every time hot or cold idles sweet and excelerates fine BUT after running WOT for a few minutes the revs die off to approx 2400 rpm .if I stop and let it idle for a while it will come good
Walfootrot
Date Joined: 23/07/12
sounds like a fuel issue, is
sounds like a fuel issue, is it overheating?
lastcast
Date Joined: 04/04/13
fuel pump mate
Mattyb84
Date Joined: 28/12/12
Shit fuel/blocked filter be
Shit fuel/blocked filter be my guess mate had the same problem changed the main filter n fixed the issue
Pgfc member
grahaml
Date Joined: 21/09/11
Loosing poweer
ive changendthe fuel filter and it didn't make any difference.Is there a check that can be done to n the feel pump or is it a matter of a new pump kit and give it a try
lastcast
fuel pump
Tough to do that as it is powered bt the motor and visa versa.
In any case merc workshop manuals (that I have seen) recommend replacing
the diaphrams if the pump is disasembled. A kit is cheap.
SpotHound
Date Joined: 06/02/14
Crack in the head?
Crack in the head opeing up unde rheat?
Jarryd87
Date Joined: 15/09/15
we had a similar drama and
we had a similar drama and replaced a diaphragm, can't remember what it was exactly for but ran fine after that
lastcast
fuel pump
You could try to see if revs increase by hand priming while you work the throttle
armature i suppose.
grahaml
Loosing powerlike i
Thanks gents
looks like I'll get a kit for the pump and see how that goes I'll let you know the out come
jeez, if there is one thing
jeez, if there is one thing Ive learnt as an engineer, it is
ALWAYS START WITH THE EASY AND OBVIOUS SHIT
Start by checking for a kinked fuel line.
When the revs die off, feel the bulb, if it is sucked down your problem is before there, if it isnt it is past there
Squeeze the bulb up when the revs die off, that will tell you if its a fuel issue or not.
If squeezing/pumping up the bulb makes no difference when its playing up then it likely isnt the pump.
As it dies off, is it missing or smooth but just losing power?
AFTER doing the shit above then look deeper
pricey10
Date Joined: 07/01/12
amen to starting with the
amen to starting with the easiest most obvious stuff.
Was just in exy and watched these guys try and get there boat going for 2 days. After a few beers we thought we better go help them. Turns out there kill switch was un plugged
Karratha. WA
big john
LOL
Gold.
jighead
Date Joined: 03/02/12
Bloody engineers
Everybody bow down.
funny
listen and learn son, or just keep your head up your ass, your choice
scano
Date Joined: 31/05/07
My educated guess would be
Problems with the fuel tank breather. If air cannot get into the top of the tank, the fuel flow will become restricted to the point it runs like crap.
seen it plenty of times with buses and trucks also.
if it starts to run bad after wide open throttle then undo the fuel filler cap and see if that makes any difference. If you hear air hissing when you crack the seal of the fuel filler cap you know you have a breather issue.
scano
Krusty
Date Joined: 27/11/15
Do exactly what Rob H has
Do exactly what Rob H has suggested....start with the absolute basics first and one by one eliminate areas until you find the problem.
The fuel tank breather is a good start like scano said and work from there.
It can and will more than likely prevent you from chasing your tail and becomming confused and spending your hard earned on parts you are "guessing" could be the problem
lastcast
fuel problem: easy + obvious
Rob h is correct. Its so obvious tho that I struggle to imagine anyone
posting this if the priming bulb is not firm to start with.
Therefore my money's still on the pump. We'll see.
Krusty
The priming bulb will be firm
The priming bulb will be firm before starting after priming but it won't stay that way once the engine is running as it has done it's job and "primed" the fuel line to the pump at the engine.
Once the engine is started It then just becomes part of the fuel delivery line, there will be no pressure there at all as it effectively becomes part of a sucsion line.
That is why Rob suggests to check it because if there is a vent problem or blockage before here then the bulb will collapse on itself as the pump is trying to suck the fuel through a restricted line. Just one of the first easy quick steps to take.
You may just be right but it pays to use the process of elimination and start with the basics.
lastcast
fuel
Ok I should have written ' cant beleive someone would post this if the bulb is not
firm to start with or if the bulb is collapsed during running or if the fuel line from the pump
is disconnected and there is fuel going everywhere or ... '
Where does it end ? There is a certain level of competency
required to not be dangerous to other people.
Anyway that's more than enough from me on this one.
Certainly dont want to upset
Certainly dont want to upset anyone but it scares me how often on here, when someone asks "my outboard wont start" and people suggest straight away a fix that involves spreading it all over the floor after waiting a month for parts to arrive!
Even for an experienced mechanic, as soon as you start undoing bolts you are introducing more factors ($$$ and complications) into the equation.
Besides the egg on face factor when ya missus walks up and asks "whats that wire hanging there?"
Y_Knot
Date Joined: 05/11/10
agree with Rob H
it could also be sucking air from fuel delivery system, loose hose clamp, small hole......
could be but that would
could be but that would likely show up straight away.
I would have thought that a damaged diaphram in the pump would show up pretty quickly also as it wouldnt get fuel pressure up for running under load, but not certain of the quirks in that
lastcast
fuel again
Second thoughts, if it's getting to and holding full revs at WOT it's probably not fuel.
Its probably electrical and I am thinking CDM or stator.
hornet42
Date Joined: 24/07/12
Fuel line
may have a kink in the fuel line after a service we have found one before
PB Dhu 850 mm Pink 820mm
Scotte
Date Joined: 07/12/06
Is it running portable tanks
Is it running portable tanks and is the breathers opening fully?thats first thing id check!
Krusty
Definitely a fuel problem !
Going by the information on how the engine is performing it is definitely a fuel problem.
It's Either a blocked or restricted air vent, kinked or split fuel line, loose or cracked fuel fitting, (You have changed the fuel filters so you can rule out that), or even an old hose that has collapsed internally restricting the flow, it could be the fuel pump, which has been mentioned ....somewhere in your fuel system is a restriction, an air leak or reduced pressure causing the starvation of fuel !!
How old is the engine ? Does it have carburetors or fuel injected ?
Because it runs for a few mins at WOT then drops revs and settles at approx 2400rpm. Then after a few minutes idling is ok again..... it is definitely starving of fuel somewhere.
Just eliminate the basics first then move to the more complicated ....the problem will stare you in the face !!
