Inline hose soap dispenser
Submitted by Josh on Wed, 2015-11-04 06:29
Hi guys
I bought a new boat, and one time I was down at hillarys I saw a guy with an inline soap dispenser clipped into his hose by the tap. Just wondering if anyone knew what it was?
boora
Date Joined: 10/02/13
Probably "Salt Away" dispenser
BCF is just one outlet "Salt Away" dispenser is usually available from - about $70. Salt Away product reputed to be very good stuff but some may differ - its not cheap. Google it to find out more.
mullinz
Date Joined: 05/12/10
I went one step further and
I went one step further and installed a petrol pressure washer on the front of my trailer with a soap injector to wash my boat down. Works a treat! Boats also to big to fit in the DIY car washes.
Jesus that looks like
Jesus that looks like something off the set of Mad Max
merdel12
Date Joined: 19/07/12
Sorta looks like it's got a
Sorta looks like it's got a face haha
Sea-weed
Date Joined: 26/12/14
Weed and feed
i use a weed and feed bottle (once emptied of coarse). Works perfectly.
Put a bit of soap in then top up with water.
shortfuse
Date Joined: 02/01/12
I used to do the reused boat
I used to do the reused boat wash pack same as weed and feed pack but found a hortex insect and fertiliser dispenser at Bunnings you don't need to pre mix the detergent as you can adjust the mix on the top of the gun. They aren't cheap but they're a bit easier to use with trigger action, mine would be 5 or 6 years old and works a treat Use it on the boat and the cars
Vinesh87
Yeh either the hortex one or
Yeh either the hortex one or a free seasol one. Both are useless for fertilizer but good for soaping the boat haha
Or a pressure washer the a detergent pickup tube.
Dougo
Date Joined: 12/08/14
Josh
Have a look at a product called Salt-away. It's sold at BCF and other outlets.
i think this is probably what you saw.
it dispenses a soapy substance and then you can move the lever and it will rinse the soap off.
I have one and it works a treat but is a little on the expensive side....... my kids bought it for me.
Katman
Date Joined: 22/08/14
Ausaca Ezyjet
Try googling a product called Ausaca Ezy Jet
Company is Vic based but may have WA distributor
I bought one from Bunnings about 2 years on clearance for $5.00 , wished I had bought a few spares
Has a jar that you fill with liquid soap and then connect to a hose , I use mine on my boat , works awesome
Cheers Katman
Taffy
Date Joined: 04/11/10
I Use a Hydro Foamer
I Use a Hydro Foamer with boat wash and wax ,soap comes out like shaving cream and hangs on the boat which saves a shit load of cleaning then just hose off
