idling boat motor while fishing... anyone??
Submitted by scottbec on Sun, 2010-09-19 07:23
Hi guys,
Just wondering how many of you guys leave your boat on and in idle, or in reverse idle to go against a drift, while you are fishing??
I figure with a 60hp 4 stroke it would only use a little bit more fuel, but will also give you the piece of mind that if you have to quickly start the boat that there wont be any issues with getting going...
Anyone have any thoughts on this one? for or against.
Cheers,
Scott
dodgy
I usually leave mine
I usually leave mine running. 150 Etec. When Im jigging its a specific peice of structure being targetted so your constantly moving around.
With a 60hp Yammie the fuel consumption at idle is so negligable it would be a concern to me.
PilbaraBrad
Date Joined: 16/05/07
When ever i am popping it is
When ever i am popping it is generally running at idle
Marky
Date Joined: 01/05/09
Yea i usually leave it going
Yea i usually leave it going a fair bit.... throwing plastics etc....
uncle
in idle
when hooked up to fast fish,to chase and follow and when casting lures
scottbec
thanks for the quick
thanks for the quick responses guys.
grayzeee
Date Joined: 09/07/09
my motor runs the entire
my motor runs the entire time i'm out
roberta
Date Joined: 08/07/08
Old fart has
also when the tide has been running a pig on his spot and his mate fished and got the fish otherwise drift would have been way to fast, I'm talking 20 miles out
His outboard is designed to run on two cyclinders when trolling, 100hp mariner.
Ginger Tablets Rock
hlokk
Date Joined: 04/04/08
I turn mine off when I stop
I turn mine off when I stop but then I have a 2 stroke :p
Blackknightz
Date Joined: 29/08/08
Leave it running
Sometimes and will put it in reverse to slow drift if a rough day, works a treat to hold you on the ground longer. I have the Yam 115hp F/S so it is quite and doesn't put the anglers off. I find on a rough day it gives the bait more action and can work a treat if all going well. need to be on the ball though and watch lines parachutes etc. Just adds to the excitment.
scottbec
thanks again so Blacknightz
thanks again
so Blacknightz - do you still put out a chute / sea anchor even when slow revesing?
DazSamFishing
Date Joined: 19/08/09
generally keep my motor
generally keep my motor idling.
Paul G
Date Joined: 12/12/07
I leave mine running all day
I leave mine running all day in and out off gear holding over spots ,mine is a 200hp honda ,mite use a few more liter for the day but it help catch fish ,and the only bad thing is the services come around twice as quick .
fisho-ron
Date Joined: 26/09/09
mine is off when drifting, i
mine is off when drifting, i dont see any reason for leaving it going, unless as paul says and you want to hold on a spot.
better resale as well with less hours on it, you try tell someone that half the hours were at idle, they think you bullshit.
i know with our engine we can get the print out of everything the engine has done, is the the same with other new modles?
PilbaraBrad
was about to say the same
was about to say the same thing as paul, i can get a full engine hour history print out
every alarm (if any)
every hour and at what rev range
service history etc
Paul G
Yes can get full print out
Yes can get full print out of hours and revs. dont even think of resale .trade in on a 350hp would be good LOL
STEVE231
Date Joined: 05/01/10
I also turn mine off. The
I also turn mine off. The only time I left it running all day was when my batteries were playing up, and I believe the extra fuel cost was negligible.
Ron, I think most new outboards can be plugged into a laptop nowadays.
seaswirl
Date Joined: 29/08/10
i am supersitious
they only have problems when you turn them off.......I never turn mine off...until i get home......
wazzbat
Date Joined: 19/01/10
We never leave it on while
We never leave it on while drifting. Like Fisho-Ron and Steve, I don't see any reason to leave it running?
Adam Gallash
Engine on
I had Ryan's boat up here and was using it every now and then and I would nearly always have the engine on whilst out fishing on my own. In my tinny I don't mind turning it off as its a pull start. 1 bad experience with electrics has got me thinking the same as seaswirl.
Paul G
I do turn off when drifting
I do turn off when drifting but that is not often.
Brucesta
Date Joined: 29/05/09
off when anchored
off when anchored occasionally leave it on when drifting but if i'm dicing with big stuff it's on idle ready to go, especially near the shore. I have a feeling that leaveing mine in idle all day while popper casting might have caused my current cold running issues which i hope are solved this week.
HuggyB
Date Joined: 03/08/08
varies
off when anchored or drifting on bottom fish (depending on how fast the drift is). I'll leave it just in gear to slow a drift on other occassions. I turn it off when drifting along for squid.
Plastic/popper fishing a reef, it's running all the time for obvious reasons!
scottbec
cheers guysI am with
cheers guys
I am with seaswirl - murphys law!!!
I have always turned it off, except for when fishing near rocks or reef or in a bigger swell. But I think I may have converted to the "on crowd".
The worst is when your battery is playing up and you want to test it by turning the boat off. The split second when you turn the key and think it wont start is not fun.
STEVE231
Can fully understand why
Can fully understand why people would not turn their outboards off, it would be my worst nightmare if I had to radio sea rescue to come and get me from 50km out. I never really show it, but I am relieved when the outboard kicks over for the final time for the run in!! Battery failure is always on the back of my mind.
just dhu it
Run when required
cant see the point in running when on the drift unless really required, ie fish coming up and may need to alter boat position, if the drift is to quick i have a second sea anchor , only then if that doesnt do it , i will resort when required to hold the boat up where the fish are congregated, the only other time is backing up to surface bommies for casting and may need to move boat when swells getting up, the theory of not turning the motor off because it may not start, well the boat shouldnt be out if you dont have 100% confidence in your gear , there will always be a time when you will need to be towed, which may have been caused by to many hours on idle gumming up the plugs or injectors IMO
fisho-ron
well said mate, after all my
well said mate,
after all my years on dirt bikes, thats what they do(foul up plugs) boats gotta be the same.
still the hours for resale have to have alot to do with it, print out or not 500hrs is 500hrs idling or flatout.
when buying a boat, one of the first things you ask is, how many hours?
but agreed sometimes it is safer to keep it running as you said.
always shut mine down after
always shut mine down after i have sussed out the drift. sometimes its a long drift and others a short one , but will always shut it down. after all running a v8 isnt cheap
. even did the same with my old boat that had a 90hp on it. got to agree with Ron and Just dhu it, idleing around will gum up the system the same as what happens in cars
Blackknightz
Yes Scot
I do reverse with the shutes out, they are on long enough string that I can see them and you have to keep in mind that I am only just in gear so no hard reversing. Just keeping it in reverse gear can get me on a rough day from 1.1kn to .6, .7 of a knot. plus it makes the bait when dropping in and out do weird up and down movements which can sometimes help with fish attraction. Keep in mind this only happens when it is very rough, days when really it would be better to be at home but in saying that I have caught some very nice fish in these conditions.
Lucky Tim
Date Joined: 28/11/07
one day way out wide we shut
one day way out wide we shut the engine down to rig up our gear and it wouldn't start. Of all the open ocean around us we were dead inline with the only exposed reef for miles. Thanksfully we dropped the anchor and it stuck, then with a little bit of DIY electrical work I managed to use aligator clips to get it going again. We fished all day and didn't shut the engine down once, caught a bag full and I wouldn't say we used any more fuel than normal. When we got back to the ramp we shut it down and it wouldn't start again.
Now that I've told my old man tale, I nearly always shut my motor down when fishing, unless it's really short drifts.
wadetolley
Date Joined: 27/06/08
Most
Most days up here the current is up. So most of the time my motor is running, and being knocked into reverse every now an then so you bait can spend a little time on the bottom.
If your worried about hours for resale..pm me!
Blackknightz
Personally after
selling boats for years I would rather see a few hours on the guage. Most average out at about 50hrs a year which is pretty common. As mentioned before the reports of the engine are the way to go. I remember when I first put my boat together I did alot of trolling over on the east for game fish and clocked up nearly 200hrs in a year but when you look at the report and most was done under the 2000rpm range trolling live bait, so it was easy work for the engine. I would think anyone that knew boats and seen that report wouldn't have a problem with the hours.
Mainey
Date Joined: 17/09/10
Battery failures
Most battery failures would be caused by having the sounder and the radio on when your out fishing and the motor off, this would only happen with a battery that is not in excellent condition.
Most common cause would be by the battery sulphating, to avoid this next time buy an AGM Marine battery as they don't suffer from sulphation.
Better idea is to run all your accessories from an independent Deep Cycle battery, using the Marine battery as the starter battery.
Maîneÿ . . .Steve Richards
Date Joined: 10/10/07
battery back up
I carry one of those portable 900amp jump start packs with me just on the off chance that my battery fails. It was pointed out to me that to set-up a dual battery system was going to cost me $300+, where as one of these unit is about $100. I just make sure its fully charged before I go out, and their lifespan is about that of your average battery anyway.
Power drain
Having your radio on draws next to bugger all current, its only when you hit the transmit button that the draw goes up. One thing to note---it is an offence to turn your raqdio off while at sea. [Would love a dollar for every time I have logged someone on to sea rescue and to call them back no more than a minute later and get no reply as the radio has been turned off]
Most times I will turn the motor off except if doing short drifts and there is a strong current.
seaswirl
new attitude
My mechanic said not to let it idle for long periods, it caused a carbon build up ...but was easy to fix, new spark plugs and some injector cleaner
