How to wire up dual batteries?
Submitted by wadetolley on Mon, 2009-03-02 13:38
Hi everyone! Going to put a second battery in my boat to run my radio,lights, sounder ect. How do i go about it?? Want to beable to charge both batteries when outboard is running. But only use one battery to start boat, and one to run the rest..cheers! Googled it but..cant find anything in my lingo
Tim
Date Joined: 26/09/06
Quick
Just did a quick search and found this. http://fishwrecked.com/node/15004
Is that what your after
** Rockingham Offshore Fishing Club **
Tim
Again
Just read it again and realized you want it to do it automatically. Basically the same wiring but with a VSR voltage sensative relay unit in place of the switch.
I just use the manual switch and change from one to the other half way thru the day.
wadetolley
Date Joined: 27/06/08
Yep
Cheers mate! Thought it must be some automatic solinoid thingy out there someone must know about. Not keen on switches..as that involves having a good memory! Might find me local Auto sparkie tomrw and see what he can recomend.
IF YOU EVER NEED A LIMOUSINE...CALL LAKES LIMOUSINES BALLAJURA
MOBILE 0416341256 OR PH 92496113
mako magic
Date Joined: 03/08/05
try dinkum auto electrics in
try dinkum auto electrics in malaga mate, they are pretty good , top guy, just behind bunnings
PH:9248 3800 unit 3/11 Alexander drive Malaga
wadetolley
Thanks mate, will suss him out!
Tim
Here
Wade have a look here
http://www.bla.com.au//index.php?fn=productGroupView&dId=1&id=588&eId=10&sId=3900723476c74f21b91c2feab0a7a579
Just have to add your batteries to it. Gives you isolators as well which is a good idea.
why spend the $ now when
why spend the $ now when your looking at upgrading anyway?
might be good to experiment on and if it works apply it to a 4x4
RUSS & SANDY
wadetolley
Good point
Good point, i have a spare battery here, and some cable....and have always wondered how to do it. Found this website....http://www.fridge-and-solar.net/dual_bat.htm
