HOT ROD THE VROD - 345 hp Verado Flash Tune - Sea trial
Time to crank up the boost pressure on my Verado 250 hp.
Just got the interface cable and flash tune from Simon Motorsport in California, complete with a 300 hp tune for use on 91 RON (USA 87 Octane) standard unleaded, and a HOTROD 345 hp tune for use on 95 RON (I think I will be feeding it 98 on this tune).
I have started with 300 hp with the current prop, will see how it goes and then prop it up and crank it to 345 hp!!!!
YEAH BOY!!!!!!
Interface cable from the States. Expensive but can be used for other Verado tune ups, just need to buy the map specific to your ECU serial number.
Hooked up with laptop ready to go. Choose your power. 250 hp, 300 hp or 345 hp! 5 minutes to reflash as many times as you want.
Reflash in progress, more boost please! -------- VRods are electronically boost controlled and all 225-300 hp Gen2 motors are identical excpet for the boost setting and fule/ignition maps. A remap from 250 hp to 300 hp is still "stock standard", I guess a tune up to 345 hp  eats into the design contingency a bit......
Would you trust your VROD with this dodgy looking bloke....
Ryan C's picture
Date Joined: 08/07/10
boosting the Verado
Tue, 2018-06-19 06:35
 well time is money John, so the quicker you can get out there the better!
Can’t see photos?
Tue, 2018-06-19 08:49
 Interesting- but id think unless you change props you will gain little except it’ll give the impression of being under propped?
ie it’ll go straight to the rev limiter?
A given prop spinning 6000rpm will give same speed whether it has 250 or 300hp behind it.
Unless of course you aren’t reaching full rpm now...
JohnF's picture
Date Joined: 07/07/10
Rob Yep, you are spot on. I
Tue, 2018-06-19 09:27
Rob
Yep, you are spot on. I am a little overpropped right now, so am gonna give the 300 hp tune a crack with the current prop and see if I can get max rpm, then will flash it up to 345 hp and try a 2 inch larger prop which I already have sorted out.
Tue, 2018-06-19 12:20
 Yeah just saw your ad for a prop.
Will be fascinated to know how it progresses!
snuffs's picture
Date Joined: 06/08/12
Interested to see how this
Wed, 2018-06-20 11:25
Interested to see how this goes. What's the estimated cost John?
Would it be beneficial/feasible on my boat?
JohnF's picture
 John, cost for the flash
Wed, 2018-06-20 12:05
 John, cost for the flash tune (which is emailed to you once you provide them the details of your ECU serial number) is US$875 or about $1200. You can use my flash connector kit. However, the flash commector kit cost me $1000, so I would look to recoup say $200 per person who uses it to cover some of my cost.
Takes all of 5 minutes to flash the ECU.
I am putting on a larger 17  pitch prop tonite and will give it a run over the weekend and will report. Then you can decide if you think its worth it.
Pretty bloody cheap hp if it works!
snuffs's picture
Thanks John, looking forward
Wed, 2018-06-20 12:43
Thanks John, looking forward to your feedback with interest.
snuffs's picture
Any idea what grade the fuel
Wed, 2018-06-20 12:51
Any idea what grade the fuel in the bowser at Hillarys marina is?
Date Joined: 27/08/09
 Standard unleaded at
Wed, 2018-06-20 13:45
 Standard unleaded at Hillarys
Mindarie has Premium unleaded
snuffs's picture
Typical ... Hillary's Marina
Wed, 2018-06-20 13:51
Typical ... Hillary's Marina is the most expensive harbour fuel in the State and its only standard unleaded ... bugger
JohnF's picture
 300 hp tune is fine on
Wed, 2018-06-20 17:23
 300 hp tune is fine on standard, 345hp neeed premium 95.
JohnF's picture
Ran the Verado at 300 hp on
Mon, 2018-06-25 08:50
Ran the Verado at 300 hp on Friday arvo with a larger 17 pitch prop. Mid range was better, much better economy and cruise speed up a bit, but a bit soft out of the hole.
Cranked up the tune to 345 hp on Saturday. Big mid range improvement where it matters, comfortable and economic cruise increased from 23 knots to 28 knots, fuel burn noticably better. Top speed increased by 3 knots without trimming and a big fuel laod, I think I will get an another two knots when fully trimmed in flat water.
We ended up running home at 30-32 knots, motor just purred along at 4800-5000 rpm, much less stressed than the standard 250 tune and 15 pitch prop.
I think it was worth while.
 What does the 235 weigh
Mon, 2018-06-25 09:02
 What does the 235 weigh John?
gruntre69's picture
Date Joined: 15/10/16
 That's interesting. Changing
Mon, 2018-06-25 11:34
 That's interesting. Changing mine down from 17P to the 15P and I notice it's much snappier out of the hole with a slight tendancy tfor the prop to slip partway through the launch. I actually think my cruise speed is similar but top speed down maybe 2 kn. WOT up from 5250 to 5700ish. Haven't had time to check out my fuel figures across RPM and trim range yet but will add it to the 17P spreadsheet and compare soon.
Seems the smaller prop give more grunt at launch and slightly less top speed. Top speed isn't that important to me.
JohnF's picture
 235 is chubby and its 25.2
Mon, 2018-06-25 12:27
 235 is chubby and its 25.2 ft overall length, so a big 23.5 fter.....hull motor and a bit of fuel is 2.5 t, up near 3.5 t with trailer and full fuel. It also has 3 fairing based transducers hanging below the hull which does not help top speed.......but helps catch fish!
 Sounds like a good result.
Mon, 2018-06-25 13:08
 Sounds like a good result. Might be an option for my new rig.
snuffs's picture
Hi Guys, thought I would
Tue, 2018-07-10 11:43
Hi Guys, thought I would provide an update for those interested.
Following on from John's update on increased performance on his Boston 235 Conquest post flash tune, I got in touch with Simon MotorSports in California to see what they could do for my Boston 255 Conquest.
My boat had twin 150HP Verado motors, which to date I have been pretty happy with, but some extra guts on acceleration would not have gone astray. So I went forward with ordering the flash tunes. My twin 150'HP had the option of being flashed to either twin 200Hp's or twin 225HP's. Due to Hillary's Marina only stocking standard unleaded (not premium) I was limited to the twin 200HP setup.
After a shaky start where the software on my laptop wouldn't copy into the Verado ECU's without error's (minor panic at this stage), the guys at Simon MotorSports talked me through it, and a change of laptop and re-install resolved the issue. End result, 5 minutes later, TWIN 200HP installed!!!
Took it for a test run on the weekend ... end result is a completely different boat (really pleased). Very noticeable increase in acceleration and mid range speed. Not a huge change in top end speed, maybe another 3 knots to 37 knots (but will test again in a few weeks time once I get the boat anti-fouled as there is some growth on it at present).
Was warming myself up on having to outlay cash to upgrade both prop's, but was pleasantly surprised (mainly due to being over propped before) that my existing prop's are suitable for the job post flash tune. WOT RPM's sitting about circa 5950-6000 RPM's pre antifoul (Verado recommended 5800-6400 RPM range).
Thanks John F for the help on the install and use of the flash tool.
JohnF's picture
 Good outcome John.  Thanks
Wed, 2018-07-11 08:27
 Good outcome John.
Thanks for the little bonus in the envelope! I owe you a beer at the MAAC!
 One thing I'm curious about,
Wed, 2018-07-11 12:13
 One thing I'm curious about, is why don't Merc (and many other manufacturers) lock their ECUs like Toyota does on some engines,preventing remaps?
It's great that they don't but I'm not sure why they wouldn't?
JohnF's picture
 They all lock their ECUs
Wed, 2018-07-11 12:57
 They all lock their ECUs  Its just that there are smarter guys out their bith a big set of skelton keys......
BMW have way more financial clout than Mercury and they lock all their ECU's, but they have all been able to be broken and their turbo 6 engines (N54/N55/S55) are a tuners delite.
 Yes, surprising though that
Wed, 2018-07-11 16:00
 Yes, surprising though that as far as I know Toyotas 1HD-FTE ECU has been unable to be remapped and it probably receives more attention for performance than most 4WD diesels over a much longer period?
Given its an 18yr old engine at least, I expected the encryption would have long been commonly available?
Also why, if Toyota have what appears to be secure etchnology, they dont use it on ALL their ECU's?
I stress that I dont have any experience on this side of tuning but am quite curious about this aspect of it
JohnF's picture
I have recently flashed my
Thu, 2018-07-12 17:03
I have recently flashed my Landrover Disco from 140 to 168 kW, huge difference. Tows the fat arse Whaler much better and even the missus recons its heaps better to pick up the kids from soccer training.....
Flashed the Verado from 250 to 345 hp...happy days!!!!
About to flash a Beemer 3L twin turbo from 320 to 400 hp at the wheels.....yeah boi.
Will I have a garage floor full of broken conrods and piston bits soon...maybe, but I am having much more fun while it lasts!
JohnF's picture
Looks like the 200 series can be done.....
Thu, 2018-07-12 17:07
 ECUWest, first again to communicate with the 200 series Toyota Twin Turbo Land Cruiser using Alientechs Tuning gear. Then first again collaborating with our expert dealers (Brett West – APE Adelaide) over the phone, whatsapp, Skype and Teamviwer, 100’s oof hours developing the best tuning options utilizing the state of the art Mainline 4WD Dyno. Sounding a bit repetitive lately do we? We we don’t care!
We know all you torque fiends out there would love another 200 Nm of torque to tow your Christmas armada around the best country on Earth – check out the results below. This is a stock vehicle and would drive just like your stock vehicle does now – just twice as good whilst using less fuel. Gains would obviously improve with 3″ TBE etc
$1200.00 for flash only or $1550 – $1600 for flash and dyno time.
200 Series 4.5DTT ECUWEST Tuning
 They have been doing the 200
Thu, 2018-07-12 17:42
 They have been doing the 200 series for a few years. Getting some pretty good numbers out of them.
Few around doing the 100 series fte’s as well.
 I stand corrected then!I was
Thu, 2018-07-12 17:57
I was under the impression (and it doesn't seem common knowledge) that the 1HDFTE could only be done with an add on such as Safari, Unichip
etc
gruntre69's picture
 Interesting, I'll soon be
Thu, 2018-07-12 18:27
 Interesting, I'll soon be towing my boat to QLD and I'm tempted to get my 200 reflashed before I leave. Does anybody know if the transmission mapping is included in the remap. I've heard the tranny and engine are controlled by one ECU on the 200. The tranny control on my 2010 is rubbish and it would be great to kill two birds with one stone..
 give reaper performance
Thu, 2018-07-12 18:43
 give reaper performance diesel a call, they have all the info you'll ever need.
https://www.facebook.com/ReaperPerformanceDiesel/
 Or toyotune. They are a 200
Thu, 2018-07-12 18:50
 Or toyotune. They are a 200 specialist workshop.
Stevo81's picture
Date Joined: 16/04/12
 +1 for ToyoTune
Thu, 2018-07-12 19:17
 +1 for ToyoTune
snuffs's picture
I chipped my Nissan Patrol 3
Fri, 2018-07-13 08:18
I chipped my Nissan Patrol 3 litre turbo diesel about 3 years ago. Huge difference in acceleration and overtaking speed. I have never looked back.
Bradg10's picture
Date Joined: 13/07/14
If anyone is interested in
Mon, 2018-07-16 13:52
If anyone is interested in flashing the ECU on a 4.2l V6 Yamaha this is also possible to do.  I have done my 225 with a ECU tune from Nizpro Marine, they have a few different options for tuning including putting a supercharger on them if you want to go to 450Hp!!!
The process is relatively simple to do and fully reversible as you download and save your current tune before putting on the new one.
I went with the 320hp option which needs to be run on 95 unleaded and am very happy with the results, way more power all round if you want to use it and at my cruise speed of 45kph using about 15% less fuel.  Cost is just under $900 for the tune and $600 for the cable/box, so fairly cheap horsepower.  Cost of a higher pitch prop could also be a factor, I went from a 17" to 19".
I was fairly comfortable doing the upgrade with my 225 as the mechanicals of the 225, 250 and 300 seem the same from my research.
Cable is available for hire for cash or beer if your anywhere near Broome.
Brad
Date Joined: 31/01/19
 interesting results . Might
Mon, 2019-02-11 13:55
 interesting results . Might be time to flash the 250 verado's on the conquest 305
Josh's picture
Date Joined: 14/09/10
 Has any smaller motors been
Sun, 2019-02-17 16:06
 Has any smaller motors been flashed? I have a Yamaha 115 which could do with a few more horses?
black gen's picture
Date Joined: 13/04/11
I’d be keen to hear on the
Tue, 2019-03-12 21:46
I’d be keen to hear on the smaller range too
have a 130 myself
