"HELP NEEDED" Still need help with floor removal
Submitted by Baron Custom on Sun, 2009-09-20 22:11
Still would like to speak to any one who know's of "BARON" Hull and floor... Were to cut to remove the floor ? What's under there ?... This spot "under fuel tank area '' has no dranage... Factory set up... Cheer's Darryl
NEVER TRUST ANY GOVERNMENT
mitch
Date Joined: 14/08/05
go for it daryl ,a few extra
go for it daryl ,a few extra drill holes and a extra billge pump in the right place will give you peace of mind...... fibre glass is cheap to buy and easy to use ....have a crack yourself mate .....heaps cheaper
Baron Custom
Date Joined: 04/09/09
On yu Mitch
Yea going to have a go... Can't be that hard to do, Done a bit of reading and im going to re-do the hole floor and V berth... Cheer's Darryl
Paul G
Date Joined: 12/12/07
If you use a drill to get
If you use a drill to get the depth of the timber floor ,then set you saw blade ,when you cut the floor you wont cut anything you shouldn't .I would cut a hole foot square and remove to have a look see,at least that will give you an idea of what is under the deck im guessing the deck is only glassed around the edges as once they sat it there they couldn't have got under to glass it ,i would think it sould have timber runners underneath the floor and glassed to the sides of the hull good luck
fishy fingers
Date Joined: 28/04/07
www.seamedia.com.au
Go here, they have done all sorts of rebuilds over the years of this type and they may just have done a Baron if they have they will give a step by step tutorial on how it's done, you could also email peter webster there to ask him, it's worth a try
fishcrazy
Date Joined: 27/01/07
jeff webster
the jeff webster secondhand boat workshop magazine is a wealth of info when your doin this it has info on everything your doin step by step with piccy too great book cheers craig
What do people actually use
What do people actually use to replace the stringers, if you don't use wood? Is it some kind of foam core composite?
fishcrazy
jarrah
i used some nice resin coated jarrah strong as ,the srtingers that were in it originally were like 2 x 1 sticks lol
Baron Custom
PM SENT
To fishcrazy
Jarrah is great stuff but if
Jarrah is great stuff but if you're going to rebuild I thought there were other rot-proof materials available.
