Help with HDS 7M
While playing onshore with my new unit, I hit the pages button and selected the Chart + info button,
Next thing i know i am in Key Biscayne WTF ??? And can't get back to home
Have i bought a dodge or has anyone else had similar problems
STEVE231's picture
Date Joined: 05/01/10
 Which Key Biscayne?? There's
Wed, 2010-12-29 20:57
 Which Key Biscayne?? There's one north of Two Rocks. Is your GPS able to track satellites? i.e. is it connected and reading outside your house?
Sounds like you're not
Wed, 2010-12-29 21:00
Sounds like you're not getting any sat con nection. Bring up the diagnostics panel.
Man Overboard's picture
Date Joined: 16/01/10
When i turned it on, it
Thu, 2010-12-30 12:37
When i turned it on, it showed the cursor at quindalup, mucked about pinging spots at wrights and Nato reef etc to get a feel, as soon as i hit the chart button i was transported to Miami on a completely differently screen setup. I lost the map layout and now have a cursor at Key Biscayne.
Unless key Largo is a Bar at Sorrento Keys I am Foocked..
STEVE231's picture
 So when you turn the unit
Wed, 2010-12-29 21:25
 So when you turn the unit off and on again does a message come up saying position acquired?
r.gates's picture
Date Joined: 15/11/10
I've got an HDS 8m
Wed, 2010-12-29 21:59
Hi MOB
Just checked on my HDS 8m and can't duplicate what you've got on your screen but try this:
Press the Pages button
Scroll to Charts via the left and right arrow keys on the keypad
Using the up and down arrow keys, make sure you've only got Charts selected
Press Enter
This should give you the chart of where you are now, assuming that your unit is On and detecting satellites......well, that's what mine is doing right now.
Hope this helps.
regards
rusty....
Pulled the pig from under the
Wed, 2010-12-29 22:18
Pulled the pig from under the carport, and looks like i have systems normal
WTF was that about,
STEVE231's picture
 Thought you disappeared for
Wed, 2010-12-29 22:23
 Thought you disappeared for a while, I would say that the unit couldn't pick up the satellites, underneath the carport it would struggle.
Good to hear it's back to normal.
r.gates's picture
Where did you but it?
Wed, 2010-12-29 22:31
Was it a US import or a locally bought one??
I got scared off buying a US import because of the 'geofence' that's included in the US versions...they aint gonna work here in Oz!!
Got a great deal on mine as the Trailcraft dealer is also a Lowrance agent....that's the least he could do for me after I bought a new Trailblazer off him
regards
rusty...
r.gates's picture
I meant 'Where did you buy it'?
Wed, 2010-12-29 22:33
 I meant 'where did you buy it'?
strike_zone's picture
Date Joined: 09/09/10
they all do that
Wed, 2010-12-29 23:56
in simulate mode ie when not locked onto sattelites if your playing with it under your carport and it does it just manually scroll the chart back to perth
Thanks guys got it sorted. It
Thu, 2010-12-30 12:36
Thanks guys got it sorted. It was under a tin roof and as strike_zone says it must of picked up satellite's when i wheeled her outside.
Local rusty, i wouldn't trust imported for something as important as this, although it did pass my mind that maybe the salesman had sold me a lemon.
All good and can't wait to get out there.
You going to bash those dhuie's with some more plastic soon Stevie boy ?
STEVE231's picture
 Too right I am!! Weather is
Thu, 2010-12-30 17:37
 Too right I am!! Weather is looking good for Monday and Tuesday and the moon is good too!!
Good to hear you got it sorted out.
