Good marine engine & leg re builders???
I'm thinking of pulling out my donk and leg in the new year after Rotto Chrissie break and doing a rebuild.
Does anyone have a good ref on anyone that can do a good rebuild on a big block V8 Mercruiser and Bravo 1 leg ...
and who does not charge an amr & a leg!!!!
looking at rings, bearings, seals, head gasket and valve grind probally. Think pistons and bore still good. Water pump is new.
Leg would be knuckle universal joint and bearings, plus lower leg seals and bearings.
Boat is at Freo Boat Park, so can be on a hard stand to lift out motor?
Tony
DhuBoi
Date Joined: 25/05/09
Hi Tony not sure about
Hi Tony not sure about pricing for a re-build,but we originally got our new 140 merc inboard/ outboard installed by Hi Tech Marine in Morley. These guys specialize in merc's and are really professional, couldnt fault anything when they did the complete engine swap , plus controls panels etc. Pretty sure they do re-builds and re-cons and everything be worth giving them a call and getting a quote. Only problem might be is the timing I think you might find they will be flat out . Hope this helps.
living is fishing
How much is a rebuild?
Tony Halliday
Date Joined: 14/06/07
I know!!!shocking how cheap
I know!!!
shocking how cheap a leg is USA side
I'd love a Volvo diesel again, but the not cheap!
maybe I buy that other berty with the diesel and swap them over and sell of the second one for less!
NO NO NO! Keep the other
NO NO NO!
Keep the other spare berty for a shaft-drive sportsfisher, ala the rebuild from the other page :P
Tony Halliday
please don't temp me!!!
please don't temp me!!! divorce would be kind compared to what "she who is alwasy obeyed" would do to me!!!
but dam that would be a good project with the trailer and all to do a centre consol conversion and all...,mmmmm
Rod P
Date Joined: 20/05/08
Is that a bravo 2 or just a
Is that a bravo 2 or just a alpha..?
Still need the transom plate and exhaust horns aswell.
But then maybe you should go
But then maybe you should go diesel? This one is $7k, and comes with a whole spare bertie!
squidvicious1
Date Joined: 22/07/10
bravo marine at beechboro rd
bravo marine at beechboro rd embleton. they work on a lot of boats in freo. i get my yamaha serviced by them, great blokes.
The_Wanderer
Date Joined: 24/09/08
If you Build it Tony Till
If you Build it Tony Till will come...
seaswirl
Date Joined: 29/08/10
been down that road
Get a new leg from the USA....I had a quote to rebuild my gearbox for 3K.....got a new one delievered for $2500 including GST.....with a 3 year warranty.....
Tony Halliday
looks more and more like I'm
looks more and more like I'm going to bring in a new leg and spares kit for the V8 and do the rebuild myself on the motor.
just waiting for The Boat Business to call back, Troy was driving when I called him. Lets see what he can do for me, as he works in the FBL facility quite often.
Ados
Date Joined: 28/06/10
Leg and engine parts
Try this guy he might be able to help you, http://www.boatpartsaustralia.com.au, saw him at mandurah boat show
